01-27-2019, 02:10 PM | #1 |
Rep 5,623
i was doing an oil change on my m6 today and noticed in the oil filter box it came with:
1. oil filter rubber o-ring 2. drain plug washer 3. bigger washer 4. smaller rubber o-ring i changed 1 + 2 but couldn't find where items 3 + 4 are located.
01-27-2019, 06:12 PM | #2 |
Rep 7,477
The e70 X5M & e71 X6M uses the same oil filter kit...and they have an additional screw plug that uses the parts that you pictured. They are used for #3 & #4 in the diagram below which is for an additional drain plug in the oil filter cover (#2). If for some reason you had to replace #2 (the oil filter cover) and the replacement has a drain plug...then you will need to use those additional pieces:
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 01-27-2019 at 06:18 PM.. |
01-29-2019, 07:47 AM | #3 |
Rep 51
Noticed the same thing and assumed they were for another model. Cars not blown up yet so I think I'm all good
