      07-17-2019, 04:54 PM   #1
E55 Bulldog
E55 Bulldog's Avatar
25
Drives: 2014 M6 GC
Downpipes Installed - rough idle?
I installed my downpipes over the weekend and now Im getting a bit of rough idle... is this normal?
Its not horrible, just a little bounce / dip while sitting at stop lights.
1997 HMC4 Hummer H1
2003 KSC2 Hummer H1
1969 Jaguar XKE
2014 M6 GC
      07-17-2019, 06:36 PM   #2
Whipple
Whipple's Avatar
263
No Rough Idle here , mine idles smooth as stock did you double check everything is plugged in correctly and the grounds back on the DME’s , install requires , DME grounds removed, O2 sensors to be unplugged and removed , and the PCV valves disconnected
      07-17-2019, 07:06 PM   #3
E55 Bulldog
25
Drives: 2014 M6 GC
Yeah, I did the install myself and double checked everything. I will have another look.
1997 HMC4 Hummer H1
2003 KSC2 Hummer H1
1969 Jaguar XKE
2014 M6 GC
      07-17-2019, 08:06 PM   #4
Whipple
Whipple's Avatar
263
Yeah Just double check everything,if everything looks good just give it about a tank of gas for the DME’s to adjust to the new pipes, mine actually felt a little sluggish when I first installed but ran great
      07-18-2019, 01:40 AM   #5
Airz
Drives: 2015 M6 Sakhir Coupe
If it doesn't clear up then it could be a damaged o2 sensor as they are quite brittle and don't like taking knocks.
