11-21-2019, 03:34 PM | #1 |
Rep 68
Help... Dealer isn't making sense on a fix.
I bought my car about 6 months ago. A few weeks later I received an Engine Coolant Level low warning. I took it in and got it refilled. A month later, it happened again. Every few weeks it's been happening and I've been getting it refilled until it started happening just a week after refilling. To be clear, this is the main engine coolant.
I took the car into the dealer and they ran a free pressure test for me. They told me no leaks were found for the main engine coolant (which is what I've had to refill every few weeks) but that the turbo coolant line had a leak in it. They want me to fix the turbo coolant line... but I don't see how that would fix my issue where I'm constantly having to refill the main engine coolant. They don't seem to see the flaw in the logic. Does this make sense to anyone? |
11-21-2019, 04:01 PM | #2 |
The Quiet One
1711
Rep 624
This states there are two cooling circuits. One for engine, and one for chargers.
‘newTIS.infobeta Home / BMW F13 M6 Coupe / Electrical Components / Connectors / Components / Components with M / M253 Coolant pump in low-temperature coolant circuit / Coolant pump in low-temperature coolant circuit Due to the turbocharging and the compact arrangement of the exhaust turbochargers, a large amount of heat is generated. Great importance is attributed to the cooling accordingly. In addition, an indirect charge air cooling was developed for the first time with which the charge air is cooled via an air/coolant heat exchanger. The engine cooling and charge air cooling have two separate cooling circuits. The engine control unit is also integrated in the cooling circuit for the charge air cooling. Functional description The electrical coolant pump works according to the principle of a centrifugal pump. The coolant pump is integrated in the cooling circuit (low temperature) and is used for the charge air cooling. Communication from the coolant pump to the engine control is effected via local interconnect network bus. The speed specification and the read-out of the current pump speed, as well as other pump values, are realised. The following values are used for the activation: Ambient temperature Difference between charge air temperature and ambient temperature‘ It looks like there is one pump. I hope the Wise chime in as I too am interested to learn more on this.
2013 M6 Coupe Sakhir Orange Metallic / Sakhir Orange \ Black Merino - The Prince
2013 X5 LCI 35i Jet Black / Black SensaTec - The Horse 2013 X5 LCI 35i Space Grey Metallic / Black Nevada // Sport Pkg - Daughter’s 2013 X6 M Sapphire Black Metallic / Black Merino \ Carbon Fiber - Son’s |
11-21-2019, 05:56 PM | #3 |
Rep 238
Drives: BMW M6 comp
Garage List 2019 Aprilia RSV4 [0.00]
2015 Land Rover Ran ... [0.00] 2014 MV Agust Rival ... [0.00] 2009 KLR650 [0.00] 2016 Kawasaki KX450F [7.50] 2016 BMW S1000RR [8.50] 2014 BMW M6 [8.00] |
so filling in thru the main coolant port refills the whole system correct? Theres no separate 'fill' area for charge air?
11-21-2019, 09:11 PM | #4 |
Rep 68
11-22-2019, 09:09 AM | #5 |
Rep 315
I found THIS THREAD very helpful.
I just went to my local auto store and purchased BMW-approved coolant (for later-year European vehicles). Topped off whichever was low (actually did both tanks), and message went away. Good luck! - Leo. |
11-22-2019, 11:06 AM | #6 |
Rep 238
Drives: BMW M6 comp
I can't find the turbo tank, can you help me locate where it is? I just see the main coolant port, which is topped off. Thanks!
11-22-2019, 01:07 PM | #8 |
Rep 315
NorthCountryGuy1711.00 jjasonSU194.00 |
11-22-2019, 01:10 PM | #9 |
Rep 315
I think this makes sense.
The turbo lines are leaking, so you'll always have that warning message. The engine lines are fine, but because the turbos are running extra hot, the engine will need extra coolant from its own reservoir to cool itself down. Thus the statement "engine coolant will become low over time". I think. Still, they are two separate systems, but you need both to work so the engine bay as a whole is cooled. I would recommend repairing the turbo leak as soon as possible. |
NorthCountryGuy1711.00 |
11-22-2019, 02:35 PM | #10 | |
Rep 68
But they said the engine coolant warning only comes up for the engine, not the turbo. And I've been having to refill the engine coolant one several times. |
11-22-2019, 02:42 PM | #11 |
The Quiet One
1711
Rep 624
There are two systems but they share the same pump. There is likely some diverter apparatus. I leak in one could (and is) effecting the other.
11-22-2019, 03:40 PM | #12 | |
Rep 315
If you're topping off the engine tank but haven't looked at the turbo, it's possible that one is way low.. Another thing to try: top off both tanks and see if the message goes away. It might, but then (knowing we have a leak), it would come back on. Perhaps longer than a week's time now. Still, knowing that the dealer diagnosed a leak in your turbo lines, I would get that repaired right away. Then top off both tanks with coolant. - Leo. |
11-27-2019, 05:35 PM | #13 |
Rep 309
There is so much wrong info in this thread. There are two separate cooling systems. One is for the engine which includes the turbo coolant line and everything else engine related. That system is the high temp system which has a level indicator. So If the lines are leaking that's why your getting the low coolant message. The low temp system is for the intercoolers and intercoolers only. The level is not monitored. They are separate circuits.
14 frozen silver m6 gc
06 evo 9 2.0 6466 |
ep322.50 |
11-28-2019, 12:29 PM | #14 | |
Rep 55
Whipple260.50 |
12-03-2019, 04:54 PM | #15 | |
Rep 582
1 for the passenger compartment heating 1 for the exhaust side on the turbochargers 2 for each heat exchanger+DMEs 1 conventional for the engine Thats a total of 5
ep322.50 |
12-04-2019, 12:06 AM | #16 |
Rep 95
correct - 5 pumps. and BMW usually has a method for running the pumps for self priming and bleeding air. I know my X3 did where I had to press the accel pedal for 30 seconds with car in acc and the elec pumps turn on for filling and bleeding
2014 M6 Coupe (SG/Silverstone)
2017 X5M (LBBlue/Aragon) 2000 Z3M Roadster (EstB/Black) |
