      08-29-2018, 01:16 AM   #23
Mr. M6
Mr. M6's Avatar
149
Drives: M6
2014 BMW M6 F06  [9.25]
Originally Posted by BadSeed View Post
That is roughly 42mm length. Hope it works but take a look at your current bulb while its installed. You'll see there's not much gap from the tip of the bulb to the housing.
so no use to buy this one it will be big... i will try to find smaller
thanks for your help
      08-30-2018, 05:20 AM   #24
FBMWWINS
FBMWWINS's Avatar
604
Drives: M8C Coupé & M240i Coupé
I am definitely looking for some as well! So please if anyone have tried one or more solutions until now please report.
In the meantime when looking around I came across this:
https://www.precisionled.com/bmw-6-s...2012-plus.html
I do not know them but maybe someone have heard or purchased from them? They seem to have several LED Lighting options and the description is promising.
      08-31-2018, 06:34 PM   #25
BadSeed
BadSeed's Avatar
Drives: ///M6 GC
2015 BMW M6  [0.00]
2010 BMW M5  [10.00]
These worked on the 1st try. Either polarity doesn't matter or I just got lucky. Expecting these to give a bulb error but I haven't seen it yet.
Edit: Over the course of 3 days I've had these bulbs ON for over 12 minutes & still NO error
youtube video:
https://www.youtube.com/watch?v=ONZi...ature=youtu.be
seller link: no affiliation
https://www.ebay.com/itm/2x-3030smd-...53.m1438.l2649
      09-01-2018, 03:52 AM   #26
Mr. M6
Mr. M6's Avatar
149
Drives: M6
dont know which one to buy.. should be no error and fit...
      09-01-2018, 08:36 AM   #27
BadSeed
BadSeed's Avatar
Drives: ///M6 GC
2015 BMW M6  [0.00]
2010 BMW M5  [10.00]
Based on what I can see, 39MM or smaller will work. CANBUS LEDs are a gamble based on my experience. Sometimes no error but sometimes you get it. It depends on the car.
Other ones I was looking at but decided to purchase the bulbs I have since the seller is local & I got it in 2 days.
Others:
1. https://www.aliexpress.com/item/2Pcs...ceBeautifyAB=0
2. https://www.aliexpress.com/item/AGLI...ceBeautifyAB=0
3. https://www.aliexpress.com/item/OXIL...ceBeautifyAB=0
4. https://www.aliexpress.com/item/2x-E...ceBeautifyAB=0
      09-06-2018, 07:40 PM   #28
BMWDriverX
Drives: G12 750i X-Drive
youtube video:
These worked for me, I plugged them in this afternoon and tested them, good so far.
      09-06-2018, 08:44 PM   #29
BadSeed
BadSeed's Avatar
Drives: ///M6 GC
2015 BMW M6  [0.00]
2010 BMW M5  [10.00]
Glad to hear. I bought another pair to have as spares. I'll test them out this weekend. The original pair have had over 20 minutes of use time & still no errors.
      09-08-2018, 04:05 AM   #30
Mr. M6
Mr. M6's Avatar
149
Drives: M6
ok let me know and post pics,, i will wait for you then i will buy
      09-12-2018, 02:05 AM   #31
FBMWWINS
FBMWWINS's Avatar
604
I just ordered the ones from the EB link above. Hopefully I will be as lucky as you people have been (thus far).
      09-12-2018, 11:54 AM   #32
BMWDriverX
They work, they white light, and they brighter than stock.
      09-12-2018, 01:51 PM   #33
FBMWWINS
FBMWWINS's Avatar
604
Cool, feedback looks promising then!
      09-13-2018, 01:29 AM   #34
Mr. M6
Mr. M6's Avatar
149
Drives: M6
so when you reverse its good for the camera and clear for night vision ?
      09-13-2018, 12:13 PM   #35
BMWDriverX
Yes it's brighter so you can see better
      09-15-2018, 03:16 AM   #36
Mr. M6
Mr. M6's Avatar
149
Drives: M6
ok i will order it, thanks
      09-26-2018, 08:52 AM   #37
BadSeed
BadSeed's Avatar
Drives: ///M6 GC
2015 BMW M6  [0.00]
2010 BMW M5  [10.00]
Lost count on the amount of minutes I've had the LEDs ON since installation. Still no errors.
      09-27-2018, 10:19 AM   #38
OTJeebus
OTJeebus's Avatar
Drives: 992 GT3 M8cGC
Did you guys install them yourselves?
      09-27-2018, 11:09 AM   #39
BMWDriverX
Yeah, takes 15 mins through the trunk, you just have to remove those screw in push fittings and then pull the carpet back a little on the trunk lid to access the reverse bulb, it turns out of the socket.
      09-27-2018, 11:11 AM   #40
BadSeed
BadSeed's Avatar
Drives: ///M6 GC
2015 BMW M6  [0.00]
2010 BMW M5  [10.00]
I did mine by following this video:
https://youtu.be/eOqV-874JHo
I did remove 1 or 2 more fasteners than what the video shows.
      10-03-2018, 09:10 AM   #41
XxTORONTOxX
Drives: BMW F13 M6
I checked that link and its says its not compatible with a 2013 m6 coupe????????????????????????????????????????????? ??
      10-03-2018, 09:11 AM   #42
XxTORONTOxX
Drives: BMW F13 M6
youtube video:
I'll just leave this here just in case:
FRM 3090 - AUSG_24_RFS_L_WARM_UEBERW_AKTIV - Left Reverse Bulb - Warm light bulb check
FRM 3090 - AUSG_24_RFS_L_KALT_UEBERW_AKTIV - Left Reverse Bulb - Cold light bulb check
FRM 3090 - AUSG_24_RFS_L_IS_LED - Left Reverse Bulb - is LED
FRM 3090 - AUSG_25_RFS_R_WARM_UEBERW_AKTIV - Right Reverse Bulb - Warm light bulb check
FRM 3090 - AUSG_25_RFS_R_KALT_UEBERW_AKTIV - Right Reverse Bulb - Cold light bulb check
FRM 3090 - AUSG_25_RFS_R_IS_LED - Right Reverse Bulb - is LED
it says it doesnt work for the m6 coupe????
      10-03-2018, 09:53 AM   #43
BadSeed
BadSeed's Avatar
Drives: ///M6 GC
2015 BMW M6  [0.00]
2010 BMW M5  [10.00]
It's not compatible w/ my car either but it works. Can't expect the manufacturer to test on every vehicle ever produced that uses that bulb type but ultimately it's your call
      10-03-2018, 11:45 AM   #44
BMWDriverX
It works, spend $20 and live the dream
