      11-13-2019, 10:16 PM   #1
Monteblueem5
Drives: 13 m5
New sceen installed today
I wanna do the nbt evo is it play and play
      11-14-2019, 06:28 AM   #2
F82_zoe
Drives: M6
I'm confused did you install it already ?
      11-14-2019, 07:49 AM   #3
Monteblueem5
Drives: 13 m5
Yeah just the. Sceeen
      11-14-2019, 09:50 AM   #4
jjasonSU
Drives: 650i, NSX
Thumbs up for the track
      11-14-2019, 07:43 PM   #5
Whipple
Whipple's Avatar
263
Can any of you guys that install these list the part#s and do a pictured tutorial on installation , what and how to remove the trim pieces , is there anything to modify or is it plug and play
      11-14-2019, 07:57 PM   #6
Monteblueem5
Drives: 13 m5
It’s plug and play you need a different bracket the the sceen sits in
Basically it’s fairly easy to swap the screen
1 start by the cluster there’s a trim that covers
The carbon fiber trim just pull it nice and easy it will come out
2 grab the trim from the top whrere the bottom of the
Sceen sits and pull trim it should come out nice remember to unplug 2 plugs on the center trim
Before you move it out of the way
3 there’s 2 screws one on the left and one and the right
Remove both of them now if you wiggle screen it should
Come out there’s a plug on the bottom of the screen and there’s a plastic piece that holds the wire in place remove it with a flat head then unplug
      11-14-2019, 09:52 PM   #7
Bmwtechgeek
Drives: Bmw m5
I was going to do NBT evo until I discovered there is no touch screen possibility. Everything relies on idrive controller which was a deal breaker for me.
      11-15-2019, 08:39 AM   #8
RagtagXMASTER
RagtagXMASTER's Avatar
119
Drives: 2013 M6
i did i write up with no pics in it
https://www.6post.com/forums/showthr...hlight=nbt+evo
i guess i should finally finish that and add the pics to it.........
      11-16-2019, 11:44 AM   #9
Friscom6
Drives: 2012 m6
Did the steering wheel volume controls still work
      11-18-2019, 08:13 AM   #10
RagtagXMASTER
119
Drives: 2013 M6
on nbt evo retrofit, yes
      12-03-2019, 10:06 PM   #11
4Romie
Drives: 2013 F10 535I / Lime Rock M3
2013 BMW M3  [0.00]
2013 BMW 535  [0.00]
Originally Posted by Monteblueem5 View Post
Attachment 2179289
Attachment 2179290
Attachment 2179291
Great job where can I find this new screen. its a must have for X-mas
      12-08-2019, 06:24 AM   #12
Monteblueem5
Drives: 13 m5
I’m sell you mine as I upgraded to nbt evo and I wanna do touch the screen I have is perfect for the older
Units pm me
