      09-10-2018, 01:13 PM   #1
DRock3d
Kraut Driver
DRock3d's Avatar
Drives: 2014 650i GC/2011 335is DCT
2014 650i Gran Coupe  [0.00]
2011 335is  [1.00]
2007 328i  [2.00]
Coolant Loss
2014 650i n63tu
Both reservoirs were near empty and I don't see any sign of leakage around the turbos. Are there any common leak points to check?
What level should the rear reservoir be filled to?
      09-12-2018, 04:18 PM   #2
TT BT
The cars we drive say a lot about us.
TT BT's Avatar
49
Drives: 2020 BMW M850i
you might want to check this for the coolant leak
https://f10.5post.com/forums/showthread.php?t=1275796
A bad day at the Racetrack beats a good day at the office
      09-12-2018, 04:40 PM   #3
DRock3d
Kraut Driver
DRock3d's Avatar
2011 335is  [1.00]
2007 328i  [2.00]
all clear there. no idea where it's going
      09-13-2018, 03:29 AM   #4
elvisisdog
Drives: F06 MSport 2013/09
You checked your oil for any signs of emulsion?
Admittedly my warning light came on the other day and the reservoir was much lower than the low indicator in the bottle. Not started to investigate where the coolant had gone - I'm hopeful it's just a little evaporation over time but even for that to be true it would imply there is some point for Steam to escape.
      09-22-2018, 06:16 PM   #5
Angry Ketchup
Angry Ketchup's Avatar
England
61
Drives: 650i (F12)
Cool
I was adding 1L of coolant every 500mi and the dealer checked it under warranty multiple times... "It's fine!"
Then, finally, they said they found a bad weld on the radiator and replaced the entire radiator assembly. No more leaks... ?
