06-06-2019, 06:20 PM | #2 |
Rep 5,577
06-06-2019, 07:55 PM | #3 |
Rep 1,031
Drives: Like a bat out of hell.
I wonder how well they will perform packed with ice and snow.
06-06-2019, 08:27 PM | #4 |
Both Feet In
504
Rep 263
Drives: 2011 SG DINAN E93 M3
Given some of the opportunities they have had with the tweets in OPE applications, it will be interesting on how they perform in automotive situations
06-06-2019, 09:30 PM | #5 |
Rep 67
Jeez...how much longer do we have to wait? Ive been seeing these things since i graduated highschool in 2007.
18' M2 Alpine White
06-07-2019, 07:50 AM | #7 |
Rep 3,537
OK put a sidewall on it and lets get this out already! Its only been 10 years since it came out.
06-07-2019, 08:16 AM | #8 |
Rep 233
06-07-2019, 09:24 AM | #9 |
Rep 18,719
I can just see it... every 10 miles some other driver will pull up along side you frantically pointing at your tires like something is wrong.
Last time I checked, rubber is heavier than air. It looks like the rubber support structure takes up about 80% of the tire's air space. They'll add some serious unsprung weight.
06-07-2019, 09:46 AM | #10 | |
Rep 3,537
06-07-2019, 12:13 PM | #12 |
Rep 568
06-07-2019, 12:46 PM | #13 | |
Gateropode
329
Rep 2,848
In term of weight, you exchange the sidewall for these inner ribs. Looks like the ribs are going to be heavier, but maybe not that much more so given that the sidewall must be steel-belt reinforced to endure the abuse of lateral flexing in corners. |
06-07-2019, 01:08 PM | #14 |
Primo Generalissimo
4669
Rep 4,022
Drives: All of them
Garage List 2017 Porsche 911 Ca ... [10.00]
2023 BMW M2 [9.00] 2023 Porsche Macan GTS [10.00] 2022 Ford F-250 Tremor [8.50] |
I suspect it will ride very similarly to crappy Bridgestone run flats.
06-07-2019, 01:15 PM | #15 |
Rep 9,160
06-07-2019, 02:24 PM | #18 |
Rep 2,232
Along the lines I was thinking too, although I was closer to 800 mmHg.
Seriously though, I wonder how these would react to turning and cornering forces, the shoulder seems so small. I would imagine that the side of the tire might end up folding onto itself and collapsing with hard cornering/turning forces. |
06-07-2019, 02:43 PM | #19 | |
Rep 233
06-07-2019, 03:25 PM | #20 |
Rep 18,719
No, they were designed for the i3, but it ran short in testing...
06-08-2019, 08:40 AM | #21 |
Licensed Professional Slacker
1240
Rep 780
Drives: 2024 M2 and 2023 Mazda CX-30
Let me see, when is the last time I had a flat or a tire failure? Oh yeah, like I think Reagan was president. I will stick with air in my tires, Bob.
06-23-2019, 04:24 AM | #22 |
Rep 228
Drives: Drives 2023 G16 840i
Interesting development in the tyre space - have seen something similar a few years ago for construction/farming use, but this is quite significant I think for cars if it comes to being.
https://www.dezeen.com/2019/06/19/mi...s-tyres-uptis/
Previously owned BMWs
1999 E46 323i SE, 2002 E46 LCI 330d SE, 2006 E83 X3 3.0d SE, 2007 E87 118i, 2010 E84 X1 18d, 2015 F10 535d M Sport, 2019 G02 X4 M40d |
Grumpy Old Man6474.50 |
