06-13-2021, 09:15 PM | #1 |
Rep 55
Decision time: Swap out the OEM Dunlop RFTs for regular tires?
I know it's been a fairly popular topic here, but with my Dunlop OEM RFT's near the end of their life and it's time for my first new set of tires, what's the right call?
1. Get another set of the Dunlop RFT's. 2. Stick with RFT's but switch to a more rationally priced brand and model 3. Ditch the RFT's altogether and switch to normal tires. If so, what brand/model? The big question for me is: How much of a ride quality improvement comes with swapping out the RFT's for normal tires, keeping with the low profile spec, on 20" rims? My Dunlops lasted under 15K miles, and experienced uneven wear (cupping). Please fire away with your best advice/experience. Thanks! Ron
Ron
2016 640i Gran Coupe M Sport/Glacier Silver (F06) 2006 325i/Graphite Grey (E90) |
06-13-2021, 09:39 PM | #2 |
Rep 628
The NRFT is much more comfortable, quiter and handles better. Which one to get depends on how you drive.
BTW, cupping can be an indication of week shocks. Make sure to get that checked as well.
F06 M6 Grand Coupe CP
06-13-2021, 09:41 PM | #3 |
Rep 404
Ditch the RFTs. If you have roadside assistance, no real need for a spare anymore. The ride is much better on conventional tires. I run Kuhmo PS91s they are a replica of the PS4s for about half the price. If money is no object the PS4s are still the best though.
06-14-2021, 09:10 AM | #4 |
Rep 1
Those Dunlop RFTs where some of the worst tires i have ever owned. Had a tread separation on one and a rear get a nail that could not be repaired.
Decided to go none RF since I could buy all 4 for almost the price of 1 Dunlop. What a change. No more hitting the gas and watching my DSC light flashing on an off, better ride and few buck in my pocket. FYI I have road side through my Ins.so just tow it to tire shop if I need to. |
06-14-2021, 10:11 AM | #5 |
Rep 75
Yep agree with the ditch the run flats. Everything is improved, noise in the cabin reduced, handling better, over bumps much smoother, probably also a very minor increase in fuel economy. Best thing I've done to the car! I went for PS4's
06-20-2021, 07:38 AM | #8 |
Rep 284
06-20-2021, 08:02 AM | #9 |
Rep 738
I went with Continental tires and TSW wheels replacing the 351 wheels and shaved off 20 lbs per corner. Drives so much better. I posted the following on the Corvette Forum about flats and non run flat tires and think it's appropriate here:
A little reality. There are exceptions and that's when a tow truck is needed. But, almost all flat tires are caused by "SLOW" leaks from punctures from nails, screws, etc. Your TPS system will alert you if you have a tire that is going flat long before it goes flat. Consider the nail/screw as your temporary plug. Leave it in the tire. All you really should carry is a small air compressor. And if you don't have one, most likely you can get to a gas station to pump the tire up to it's maximum pressure indicated on the tire which is 51 psi before it actually goes flat. While monitoring the rate you are losing air pressure with your TPS system you can see when you will have to stop and refill the tire with air. Most likely, hundreds of miles. All this crap about jacks, lug wrenches, tire plug kits, slime, etc is just that, crap. Get a small air compressor and don't worry about flats. |
06-21-2021, 04:38 AM | #10 | |
Rep 121
Those M351 alloys are hefty weighty (+ 14 kg) while good sensible priced aftermarket alloys can reach under 10 kg. Yes, like wise you could think you must move one day, should you buy a truck to be your every drive car ? |
09-10-2021, 10:09 PM | #11 | |
Rep 788
09-19-2021, 05:26 PM | #12 |
Rep 103
I have found that runflats are only good for getting knots on them and bending wheels. I went for well over 30 years and didn't have a flat until I bought my BMW with runflats. In the last four years I have so far replaced 13 tires on my 535i X Drive M Package.
I have also had 12 original BMW M wheels on it, all from bending from hitting bridge gaps (expansion joints) on the expressway or minor potholes. Runflat tires are really hard on wheels. I am getting ready to HAVE to put another set of wheels on the car because the M wheels I have on it are all four bent and all four tires have serious knots. Tread still looks like new and only 3 years old, Runflats Suck. This time I am going NON-Runflat. Ed |
09-19-2021, 08:51 PM | #13 |
Rep 38
Replacing my RFT were the best decision I've made in my 6 years of ownership of this vehicle. I went with Bridgestone Potenza S007 I believe
09-20-2021, 03:17 AM | #14 |
Rep 44
I had the OEM Dunlops which were very good when new but the compound seemed to go very hard after getting half worn .
I wanted to keep the run flat capability so I bought a full set of Michelin Pilot Sport 3 Zero Pressure . Staying with the standard tyre pressures they are riding well but more importantly very good in the wet and I have the security of not being stranded in an area I wouldn't want to be in !. |
09-21-2021, 12:46 PM | #15 |
Rep 104
Just piling on at this point but why not:
-OEM RFTs are terrible. They ride harshly, get damaged over potholes, and grip poorly. -RFTs are completely unnecessary if you have AAA or other roadside assistance. Keeping a pump in the car helps too. Never needed AAA for a tire issue. -As everyone will tell you, switching to non-RFT is a night & day difference in ride/noise. -Tried Bridgestone S007A first, liked em but they wore out quickly (15k front, 10k rear), disappointing grip. -Currently on PS4S, love em, amazing grip, we'll see on wear. |
