      11-29-2016, 10:32 AM   #1
Mr. B
Drives: Montego Blue 335
Best Oil for M6
I am sure there are posts on here but I couldn't find anything answering what the best is.
I just purchased a 2014 M6 GC Competition Package and I want to purchase a couple quarts of oil to keep in the trunk as I did with my M3. I am seeing 4 different options. The 0w30, 0w40, 5w30 and 5w40. Now which is the best to go with and brand? I live in warm Miami so don't need anything specific for cold weather.
thank you.
      11-29-2016, 12:49 PM   #2
S800vxr
Drives: F13 M6 Coupe
I use 5w30 and a well known make (varies depending on what specials are running). I do however change it every 3-4K miles and not the pathetic long intervals BMW suggest!!
      11-29-2016, 02:14 PM   #3
melvyn
Drives: 2018 M3 CS
That's calling the kettle black, BMW engineers are crap but you buy specials and change every 3-4K .Why would you want to change your oil at that small mileage .
      11-29-2016, 04:13 PM   #4
Mr. B
Also. What i guess i should know what oil was put in it on the last oil change huh? would be bad to miX?
      11-30-2016, 02:27 PM   #5
CSL335i
Hungary
207
Drives: M2 and...
I am using two oils at my BMWs. At F13 M6 i am using Motul 300W 5W40 with maximum 8k km change intervall (no track drive). On my wife m235i i use Shell Helix Ultra 5W40 with maximum 10k km change. On my M2 at the first oil change we have put BMW M Performance 0V40 oil (aka Shell Helix), but the next oil change, i will change it to Shell 5W40 or Motul 300W 5W40 with 8K km intervall.
      11-30-2016, 08:22 PM   #6
Bimmma
Bimmma's Avatar
43
Drives: E92 M3, F06 M6
I just picked up a couple quarts of 5w30 for my M6 GC. Based on VIN, dealer gave me the 5w30. I'm also in south Florida.
      12-06-2016, 04:24 AM   #7
KauvSTi
Super Member
KauvSTi's Avatar
129
Drives: M6, M8 Comp, S63, 720S, F8
I change my oil every 3-4K miles as well, I drive my M6 hard every now and then and by 3k miles the oil is black. I just recently switched over from the original twin turbo BMW oil to 5w-40 Liquid Molly. So far I like how it doesn't burn as fast as the BMW Oil. I would always have to add a qt when I would get close to 3k. I was told this is normal, I have yet had this issue while running liquid Molly.
      07-13-2017, 01:32 PM   #8
My13M6
Theo
Drives: F13 M6 coupe
Hi guys,
here is what I use on my M6 F13 and believe it or not it does not burn oil anymore..
Liqui Moly 2249 Leichtlauf Special LL 5W-30 Motor Oil..
Also I change my oil every 4-5k miles just to be in the safe side(turbo maintenance)..
      07-15-2017, 06:35 AM   #9
mjposner
mjposner's Avatar
898
Drives: 2020 Z4 40i
I am burning a quart every 700 miles on BMW Twin Turbo Oil. I see some of you state that the Liquid Moly does not burn. What was your oil burning consumption before?
      07-18-2017, 12:07 AM   #10
melvyn
Drives: 2018 M3 CS
0w-30 is the correct F06,F12-13 M6 oil.
      07-18-2017, 07:59 PM   #11
hirkaismyname
Drives: F06 CP GC
Any reservations against Royal Purple?
      07-21-2017, 09:07 AM   #12
KauvSTi
Super Member
KauvSTi's Avatar
129
I would get the add a qt after 2500-3k miles when using the original. Now with the Liquid Molly 5w-40 I have yet to receive that message and I've been using it for over 7months now.
DME Stage III, Catless Downpipes, SSP Basket & Clutches, 3.5" Custom Intakes & Eisenmann Race Exhaust
      07-21-2017, 07:07 PM   #13
mjposner
mjposner's Avatar
898
Drives: 2020 Z4 40i
I think 5w-40 is too thick. Could damage engine
      07-26-2017, 10:15 AM   #14
Mnite_S63
Drives: 2013 F13 M6, 2010 X5M
Been using Liqui Moly for my BMW and Audi's no issues.
For M cars been using the per Liqui Moly's advise
Leichtlauf High Tech 5W-40
      07-26-2017, 02:19 PM   #15
BMWRog
Drives: 2014 M6 Convertible
In the UK, BMW recommend 0W-30 for the M6. I'm changing oil at about 8 to 9000 mile intervals, and so far have never needed to top it up at all. The electronic oil gauge indicated still at maximum just prior to the last oil change. That's if the gauge is to be believed! I've a BMW Service Pack on the car, but the last £00 invoice doesn't state what make of oil my BMW garage put in...
      07-27-2017, 01:57 PM   #16
BMWDriverX
Drives: G12 750i X-Drive
How are you guys resetting the service on the idrive after you change your own oil?
      07-28-2017, 01:58 AM   #17
melvyn
Drives: 2018 M3 CS
You cannot
      07-28-2017, 02:55 AM   #18
BMWDriverX
Originally Posted by melvyn View Post
You cannot
Are you sure? I looked it up after posting and it seems that you can via the trip reset button procedure.
      07-29-2017, 03:23 PM   #19
melvyn
Drives: 2018 M3 CS
Very sorry, misunderstood.What I should of said was, you can't enter an oil change and store it on idrive
      02-06-2021, 04:53 PM   #20
moto650i
Drives: 2006 650i
I change my oil once/year whether it needs it or not.
Cheapest thing you can do for your car.
Coming from the Motorcycle World, you will find that this is the single most discussed, and disagreed upon topic.
I also believe that if you rarely if ever encounter temps at or below freezing, 0w is not necessary, and 5w is fine. And on the top end, if you don't see 100 deg F often or at all, 30w works. Everything else is personal preference.
      02-06-2021, 05:26 PM   #21
MetZF82
Drives: 2015 F06 M6
I had the same issue. I don't think this is an oil issue. Your crankcase valve vents might be clogged like mine. I would change those out. Once I did I got the add quart more so around 2500+.
As for the original post I use the oem oil and i change my oil every 2.5k-3k miles. I drive rather aggressive and have stage 2 tune fyi.
      02-06-2021, 05:47 PM   #22
ishm6
Drives: BMW M6
0-w40??
