      09-13-2020, 01:51 AM   #1
MaximKarpovich
Drives: BMW 650i
e63 + 437m wheels
Good day,
Is it possible to put 437m wheels on e63 (not M) R19? Would it be any issues then?
Thank you
      09-13-2020, 02:21 PM   #2
brad850csi
Drives: 16 F13 M6 Comp
It will work with spacers but they will be big spacers. The stock E63 wheels are 19x8.5" 14mm and 19x9.5" 14mm or 18mm offset (depending on the style of wheel you have)
437M wheels are 19x9.0" 29mm and 19x10.0" 40mm. So you'll need around 15mm spacers at the front and 25-30mm at the rear. Not sure if your country has limitations around the size of spacers but something to consider.
A better option would be F12/13 M6 19" 344M wheels as they are 19x9.5" 31mm and 19x10.5" 19mm so you'll only need spacers at the front and maybe very thin ones at the rear.
Tags
#e63 #437
