09-06-2020, 09:39 AM | #1 |
Rep 209
640D coolant low
Has anyone noticed coolant consumption on their 640d? I've had the edge recall done which happened to coincide with the last time I had low coolant. I'm wondering if the egr is playing up again. No signs of issues around the engine, oil is as normal, no leaks.
09-17-2020, 05:21 AM | #2 |
Rep 1
Hi elvisdog, just bought mine and a week later it needed around a litre of water, it came serviced so I didn't check the levels on purchase and am now wondering if coolant usage is normal on these? Anyone else having this problem? TIA
09-17-2020, 10:33 AM | #3 |
Rep 2,026
09-21-2020, 08:03 AM | #6 |
Rep 209
I've had one of the recalls done, I thought it was the egr. Had a similar issue when the egr recall came through. Idrive came up with warning coolant was low. After the egr recall though I had no issues. I'm just wondering if the recall had put a similarly bad product on?
Surprises me how low the coolant had to be to trigger a warning. Mine was well below the minimum line in the expansion tank. It's due a service next month so will give them a call and get them to check recalls on the car. Thanks.. |
09-21-2020, 10:59 AM | #7 |
Rep 2,026
it's the egr cooler which the recall is for..mine had one in 2015 and another one in march,,it is now an upgraded part,,2015 one was like for like
