      11-16-2019, 07:00 AM   #1
NorthCountryGuy
The Quiet One
NorthCountryGuy's Avatar
1629
Drives: M6, E70, E71
2013 X6 M  [0.00]
2013 M6  [0.00]
2013 X5 LCI 35i Spo ...  [0.00]
2013 X5 LCI 35i  [0.00]
Tire Fitment Question
Guys,
Will a 305 fit on a 10.5 x 20 inch M343 wheel, and if so would it be a comfortable fit on a Coupe ?
Thanks in Advance.
Craig
2013 M6 Coupe Sakhir Orange Metallic / Sakhir Orange \ Black Merino - The Prince
2013 X5 LCI 35i Jet Black / Black SensaTec - The Horse
2013 X5 LCI 35i Space Grey Metallic / Black Nevada // Sport Pkg - Daughterís
2013 X6 M Sapphire Black Metallic / Black Merino \ Carbon Fiber - Sonís
      11-16-2019, 12:54 PM   #2
Kkgy79
Drives: 2013 m5
Originally Posted by NorthCountryGuy View Post
Guys,
Thanks in Advance.
Craig
Yes. Ps4s fits perfectly I dont know about other brands tires.
      11-16-2019, 01:39 PM   #3
brad850csi
Drives: 16 F13 M6 Comp
A lot of people have done it here including me. No complaints at all!
      11-16-2019, 01:44 PM   #4
TomM6
TomM6's Avatar
Drives: F12 M6 individual
Would you keep 265 in the front? Can someone that did the change to 305 comment on the driving feel and the cornering? Less understeer?
Thanks
      11-16-2019, 03:30 PM   #5
brad850csi
Thanks
I haven't changed from 265 at the front yet. I think that it is realistic to say that at just about any speed you can make the car oversteer if you're on the throttle and that typically the car will understeer if you're using the throttle to keep the car at a steady speed but winding more lock on. I've had understeer mostly when off the throttle completely but sometimes the rear will skip a bit if you're off the throttle and cornering or hitting a bump.
It also may be a bit different for you in an F12 as you've got about 200lbs extra weight at the rear compared to my car.
      11-16-2019, 04:26 PM   #6
NorthCountryGuy
The Quiet One
1629
2013 X6 M  [0.00]
2013 M6  [0.00]
Thanks Guys.
My M6 is being prepped for me now. I will have it next weekish depending on the weather up here. Wonít be driving it till the season and the salt goes away. Just gathering info for later. Iím considering getting the widest tire I reasonably can with the best grip (likely the PS4). My Porsche 928 S4 was rear wheel drive with a 40% LSD, but it did have weight over the rear axle as thatís where the transmission was located. A marvelously balanced, and handling car. 560 HP transmitted from the rear with no weight is something Iím going to have to adjust to.
I am really looking forward to it.
Thanks again,
Craig
      11-16-2019, 04:57 PM   #7
brad850csi
Thanks Guys.
Thanks again,
Craig
There isn't actually much difference in the weight distribution, the M6 Coupe and Gran Coupe are about 52% front, the Vert is about 49%. A quick bit of googling seems to show the 928 has 51% front stock.
My car is a 600ps comp pack and in 2nd gear on a smooth road I get grip just fine with the 305/30r20 PS4S tyres.
For 1st, if I smash the throttle off the line it'll spin the wheels so instead I go to about 50-60% throttle to get it moving, then floor it. As boost starts to come on at about 2500-3000rpm I'll shift into 2nd. That will normally result in no wheel spin at all or perhaps just a tiny bit in 1st and will regularly result in 3.7-3.9 seconds to 100kmh.
      11-16-2019, 10:52 PM   #8
NorthCountryGuy
The Quiet One
1629
2013 X6 M  [0.00]
2013 M6  [0.00]
Brad,
Thanks for the reply, and thanks for the description off the line. Iíve never owned a car with this much HP and Torque before. All will be well.
      11-17-2019, 11:53 AM   #9
Kkgy79
Drives: 2013 m5
Brad,
Thanks for the reply, and thanks for the description off the line. I’ve never owned a car with this much HP and Torque before. All will be well.
I have 265 305 set up now. I will change next spring 275/305 set up. There r many articles about tire size and under over steer etc.
who cares? Im not professional driver. Just floor it at straight line. Also i thin i can handle 50% amount of car ability at cornering. So cant feel anythinggoing wrong on corner. Just can noticeable at straight line. Feels more confident and stable. If possible, i like to put 325 on other rim. I hope this help u
      11-17-2019, 11:56 AM   #10
NorthCountryGuy
The Quiet One
1629
2013 X6 M  [0.00]
2013 M6  [0.00]
Thanks Man.
Good of you to share.
