      07-11-2018, 08:46 AM   #1
burkhacs
Drives: 2022 M240i - TNM Shadowline
Routing dash cam cables
Does anyone have experience routing power cables for their dash cam? This seems like a fairly daunting task given the arrangement of the headliner and location of the power ports. Hoping someone already suffered through this can can spare their fellow forum members some of the heartburn!
      07-11-2018, 09:46 AM   #2
mberbic
IG: @M6erbic
mberbic's Avatar
Drives: F12 M6
https://www.6post.com/forums/showpos...60&postcount=7
      07-11-2018, 09:49 AM   #3
burkhacs
Originally Posted by mberbic View Post
Thanks for this I will take a look. Not sure why this didn't show when I searched, much appreciated.
      07-11-2018, 09:51 AM   #4
mberbic
IG: @M6erbic
mberbic's Avatar
Drives: F12 M6
it's on the M6 forums not the 6 series... should be the same though
      07-11-2018, 04:09 PM   #5
siegester
siegester's Avatar
345
Drives: '20 M340i
2020 BMW M340i  [0.00]
I used the front fusebox for my front dashcam which makes routing the wires much easier. Just tuck them in the headliner, down the A Pillar, and into the dash where the fusebox is. I then used and add a fuse with a power outlet adapter and that was it.
something like these (not actual ones i used)
https://www.amazon.com/Cigarette-Lig.../dp/B07D5SS5HN
https://www.amazon.com/Support-Stand.../dp/B0146EB8EM
I haven't done my rear dashcam yet as I'm not sure how to mount it out of the way of the power window shade.
However, I did run some cables to the trunk for other accessories, and I just ran them down the door sill, then removed the seat bottoms, popped off the rear seat side back bolster and ran the wires behind the trunk panels. There was no need for a long stick once removing those items (all of which just pop in and out)
      07-12-2018, 08:47 AM   #6
burkhacs
Thanks for the info my man!
      03-11-2019, 08:56 AM   #7
raj5785
raj5785's Avatar
Drives: F15 40d Sapphire Black
2015 BMW X5 40D  [0.00]
where did you guys connect the ground cable in your glovebox?
Tags
cable, cam, camera, dash, dashcam, management
