      05-21-2017, 01:06 PM   #1
mjposner
mjposner's Avatar
900
Drives: 2020 Z4 40i
Remove Snap-in Adapter Base DIY
So I was tired of the adapter base taking up all that space in my console so I decided to remove. It was a five minute one tool job:
1. Separate plastic bottom from felt covered base with thin Name:  second.jpg
2. Push down and pull felt base away from console
3. Push plastic adapter though felt base and set felt base asideName:  third.jpg
4. Open small door in rear of console and disconnect three wires, pulling out plastic adapterName:  fourth.jpg
5. Reinstall rubber mat. I covered the hole with black felt, but for about $35 you can order the full mat (oem 51169217615).Name:  finished.jpg
      05-21-2017, 03:07 PM   #2
Airz
Drives: 2015 M6 Sakhir Coupe
That's awesome thanks very much for this. I was just thinking the other day what a pain in the arse that adapter is as it always gets in the way
      05-21-2017, 03:47 PM   #3
Cpark352
Drives: 2014 M6 gran coupe
What is the snap in adapter for? Does one need a separate iphone adapter l for it to fit?
Thanks
      05-22-2017, 05:45 AM   #4
IM6
Drives: BMW M6 F13
nice work mate, I'm thinking the same, that 1990 feature need be dropped asap.
      05-22-2017, 06:23 AM   #5
mjposner
mjposner's Avatar
900
Drives: 2020 Z4 40i
Snap in Adapter
Thanks
The car comes with the base, then you have to buy the snap in adapter for your cell phone to get any function.
Here is one write up: http://www.2addicts.com/forums/showthread.php?t=1177288
I tried using it with an iphone 4 and it was always wonky
      05-28-2017, 09:37 AM   #6
gregmb
master chief
gregmb's Avatar
Drives: 2014 ///M6 vert
Nice DIY - did it this morning to clear out some space. Many thanks for the write up!
      05-28-2017, 04:38 PM   #7
mjposner
mjposner's Avatar
900
Drives: 2020 Z4 40i
"Nice DIY - did it this morning to clear out some space. Many thanks for the write up!."
Now if we can only clean-up your avatar...Go Gators!
      05-29-2017, 04:19 PM   #8
gregmb
master chief
gregmb's Avatar
Haha - no chance - it's all about the U
      03-15-2018, 07:28 PM   #9
2th Dctr
Drives: BMW M6 Gran Coupe
my trunk lock button is on the box that holds the adapter. 2014 M6 Gran Coupe. Anyone figure out a way to deal w/this?
Flying Ace4984.50
      03-16-2018, 03:59 PM   #10
arucano
arucano's Avatar
2014 BMW M6 GC  [10.00]
center console
You can get a little plastic tray to fit in the present location. The internal of the center console is different. The part number for the tray is 51169217615. It is around $30. Turner has about the best price. The "floor of the storage space will not increase but you will add an "oddment" storage tray. The trunk lock button remains as is.
F06 M6 Grand Coupe CP
Sapphire Black Metallic
The drive is the destination
Flying Ace4984.50
      03-16-2018, 04:13 PM   #11
Flying Ace
Flying Ace's Avatar
4985
Wait, are you sure that tray 51169217615 will get him the switch? Googling the part number indicates what OP was saying in his post and that the part is simply the rubber floor mat that covers the hole.
Is the GC and coupe different? OP has a Coupe and in his pictures it clearly shows that the switch never went away during the conversion. Or if you did this on your car, maybe the model year changed the location of the switch?
      03-16-2018, 05:49 PM   #12
mjposner
mjposner's Avatar
900
Drives: 2020 Z4 40i
As you can see in the pic above the trunk lock is on the same wall as the 12 volt and usb and did not need to be removed. I have a 2013 convertible
      03-19-2018, 12:20 AM   #13
arucano
arucano's Avatar
The tray goes in the place of the phone base. The raised section is not removable in the GC. There is "no way" to get the full flat bottom other than changing out several other components or cutting it up.
you can remove the base plate 84109215826 and install 51169206734. The trunk switch remains in place.
Flying Ace4984.50
      05-08-2021, 10:19 AM   #14
JDMils
Drives: 2014 640i Coupe F13
I'm sorry for re-opening this old post, but I'm struggling to get the felt base out. Seems to be stuck in there so I'm at the point where if I can't get it out I'm going to get stuck into it with a hacksaw blade.
      05-13-2021, 11:11 PM   #15
JDMils
This is a great post which helped me get the phone holder out. One point to note, for my 2014 coupe 640i, to get the holder out, I had to slide it towards the back of the car while pushing down on the metal clip at the front of the holder. Then to disconnect the big block connector, there's a sliding lock which needs to rotate out and the block disconnects. The pink and blue connectors were a b*tch to disconnect, had to use a small flat blade screw driver to get the coloured clips off, but after working it for about 15 minutes, they finally disconnected. Now to buy the full coverage mat to cover the wire access hole and it's complete.
PS. I don't have the boot lock in the centre console.
Pics:
Tags
adapter, console
