      11-29-2020, 09:16 AM   #1
nazali
nazali's Avatar
Drives: 230 2020 vert F23
Chili for Tacos?
So I'm having problems with making mince for tacos.
the end result is tasty and full of flavor, but has loads of liquid when it settles down.
I want something a bit more "together" with some liquid, kinda like a jam or ketchup consitancy.
(how I cook)
fry onions in a dash of oil, add (beef) mince (medium), fry, add a small jar of tomatoe/seasoning.. maybe throw in a couple of spices and garlic...
had thought of the dry season, but not sure if I should add any tomatoe puree etc
any ideas ?
txs
      11-29-2020, 09:18 AM   #2
nazali
nazali's Avatar
maybe the mnice I'm using is wrong
should I use lean ground or extra lean ground ?
      11-29-2020, 09:28 AM   #3
KenB925
Drives: ZL1, Raptor
have you considered corn starch?
nazali1303.00
bimmerfrk591.00
      11-29-2020, 11:35 AM   #4
nazali
nazali's Avatar
funny, just as I was loggin on here that just clicked... hmm yeah, I'll give that a try !
txs !
      11-29-2020, 12:56 PM   #5
bimmerfrk
bimmerfrk's Avatar
Drives: Ferrari Red F83
this guy understands a thing or two. Do this.
nazali1303.00
      11-29-2020, 01:43 PM   #6
Dlpfcb
Drives: AW E92 M3
Thin chili is a result of many things. 1, when your sweating the vegetables ensure to sweat until almost dry. Add your spices to the vegetables and toast them. Then sprinkle 1-2 to flour and stir until it becomes really tight and pasty. Add tomato paste. This is also a thickening agent. Add your stocks and cooked meat and reduce until it tightens. Flour will give a cleaner taste vs slurry. The key is truly reduction and rest time. Once its reduced and starting to tighten, let it just set for 10 more minutes and the flour inside will continue to bind it together.
nazali1303.00
      11-30-2020, 11:00 AM   #7
nazali
nazali's Avatar
this is TOTALLY different to what I do LOL
I'll give it a try as well as the corn starch tip
      11-30-2020, 11:03 AM   #8
nazali
nazali's Avatar
one other thing, I'm finding I'm making too much,,, is it better to half the fresh mince and freeze it OR cook the whole lot and freeze half the cooked lot or friderate it
does freezer mince go mushy
I'm buying fresh raw mince (beef)
btw any other type of mince such as pork or mix of meats ?
      11-30-2020, 11:54 AM   #9
Alfisti
Drives: 2008 Saab 9-3 Combi
Corn starch solves everything
nazali1303.00
      11-30-2020, 12:21 PM   #10
King Rudi
King Rudi's Avatar
13154
Drives: Meat Suit
Curious as to what part of the south OP is from.
Originally Posted by jmg View Post
We're Americans. Leave your logic and science witchcraft out of this! Jesus and guns are all we need.
      11-30-2020, 12:23 PM   #11
fiveohwblow
fiveohwblow's Avatar
Drives: F15, E46 & M3, F82
Oh that's easy, I can help with that.
"here"
Ill be here all day. Let me know if you need anything else.
      11-30-2020, 12:51 PM   #12
King Rudi
King Rudi's Avatar
13154
Drives: Meat Suit
"here"
Well.....this, along with a few other red flags, is what alerted me to the OP being located in the south. I'm "here" so I knew she was too.
      11-30-2020, 12:57 PM   #13
fiveohwblow
I had to... the irony of both your locations... Its the small things
King Rudi13154.00
      11-30-2020, 03:09 PM   #14
nazali
nazali's Avatar
not from the "SOUTH" LOL
      11-30-2020, 03:10 PM   #15
nazali
nazali's Avatar
"Where you come from does matter -- but not nearly as much as where you are headed."
Murf99314114.00
      11-30-2020, 06:08 PM   #16
chassis
chassis's Avatar
6528
Drives: 9Y0 Cayenne S
Cook longer on low heat, simmering. Don’t add starch.
nazali1303.00
      12-03-2020, 08:52 PM   #17
nazali
nazali's Avatar
Hi Guy's
so today was taco night, I made 2 major changes.
1> extra lean beef
2> Corn starch (mixed with a bit of water) directly into the mix
After cooking, I really let it simmer and cook, but DD was starving so served it up.
I think also it needed some rest time to thicken as well once off the heat
By our 2nd taco, it was just right !
I'll keep playing with this, I'm finding the "taco" sauce jar is pretty bland
so I'm going to try and give it a bit of favor and play around
thanks ALLLLLLLLLL
I found the mince was a MUCH better consistency and not as much OIL puddles
I also found you need to leave it to cool down so it thickens up a bit,
previous it didn't thicken, and left overs over night had big patches of Lard all over it
Yeah much better,
So I'm heading in the right direction now
Murf99314114.00
      12-04-2020, 09:13 AM   #18
KenB925
Drives: ZL1, Raptor
Originally Posted by nazali View Post
Hi Guy's
1> extra lean beef
thanks ALLLLLLLLLL
Yeah much better,
nazali1303.00
      12-04-2020, 09:41 AM   #19
ShopVac
Not willing to take advice
ShopVac's Avatar
Drives: F82 M4 - 6MT
It's Taco Tuesday - not Taco Thursday, so that's part of the problem right there.
Just trying to help
Personally - would never use extra lean, would seem flavorless. 80/20 at the most lean...be sure to drain.
Proud owner of 4 Turbos and 1 Supercharger
chassis6528.00
nazali1303.00
      12-10-2020, 03:09 PM   #20
nazali
nazali's Avatar
yeah the beefy flavor was not as good I did note, I might actually mix the corn starch with some beef stock,
but as I said the left overs were very palatable and not needed to be separated from lumps of congealed fat LOL
I wanted to replicate it today, next week might try lean instead of extra lean
lol taco Tuesday, that's what my daughter says "it's supposed to be taco Tuesday not Thursday" LOL
Just trying to help
      12-10-2020, 03:24 PM   #21
Murf993
Murf993's Avatar
14114
Drives: Porsche 993
As long as we don't interfere with Wednesday's designation.
nazali1303.00
      12-10-2020, 03:32 PM   #22
pennsiveguy
pennsiveguy's Avatar
Drives: F15 xDrive50i M-sport
Drain off most or all of the liquid. If you need something to thicken it after that, a dab of refried beans will do the trick and won't turn it white like corn starch and won't add a strange taste that's out of place.
2017 F15 xDrive50i M Sport | Superformance GT40 Roush 511 IR FE
