      04-04-2021, 09:55 PM   #1
BBHMM
Drives: 550i
Hello everyone, is there anyone experiencing squeaking problem with CCB during low sped driving(20-30mph) Is that normal???(dealer tells me its normal)
Also this squeaking totally random, but never squick when you backing up....
Its kind of crazy for me... video attached
https://youtube.com/shorts/dlZbfscnA5I
      04-04-2021, 10:09 PM   #2
VCM
Drives: M6 GC Individual Manufaktur
Is this noise all the time?
Every time you brake wet, dry or cold brake only??
      04-04-2021, 10:12 PM   #3
BBHMM
Drives: 550i
Only when warms up and after couple of braking... or stop&go traffic
      04-05-2021, 02:39 AM   #4
VCM
I never had noise when they warm up on my CCB.
I just happened to see a video about CCB few weeks back, and thought I'd ask few things.
      04-05-2021, 09:58 AM   #5
johndeere
mhmmmm
Drives: MS3X
Mine squeek a little bit during breaking at low speeds, but never while driving.
      04-05-2021, 02:00 PM   #6
BBHMM
Drives: 550i
How many miles on you CCB?? New pads rotors?? Any lubricants? I dont mind it squick a little but its like old semi truck or train braking 😁😁
Braking power is incredible but this squeaking just super crazy here is some videos is there anyone else who had this problem?
I have feeling that mine noose even more when warmed up
Brake pads measurement:
8mm front
7mm rear
So far i have only hope that it will be less sound with new pads
https://youtube.com/shorts/dRQDthTKavc
https://youtube.com/shorts/bVU31LM9qIA
https://youtube.com/shorts/pXrd_0Td49I
      04-06-2021, 10:47 AM   #7
VCM
Got 26K kms on the car, so around 16K miles.
Still on stock set up, still lots of pads left.
      04-13-2021, 09:26 AM   #8
MetZF82
Drives: 2015 F06 M6
I have incredibly loud and annoying brake squeaking ever since I got the car.
I mean it's awful to the point where strangers tell me "I think you need new brakes!" Lol.
It's been like that since 27k mikes I now have 40k. I've tried a few different car products. Nothing seems to work 🤷🏻*♂️.
      04-14-2021, 08:50 PM   #9
BBHMM
Drives: 550i
Did you ever tried to replace brake pads?? if it helps at least a little ill do it😁
      04-16-2021, 01:25 PM   #10
MetZF82
Drives: 2015 F06 M6
My pads are no where near due for replacement so I wouldn't spend all that money on these pads for a little less squeaking.
      04-16-2021, 02:55 PM   #11
Msparta
Drives: X6M
The fix is easier then you may think... I have CArbon ceramic breaks on my m6 comp package and had replaced the pads when I purchased my 2015 beast... yes the squeaks are a pain in the rear and constant but after hours and hours of research I found the fix to be super easy:
Get a decent pressure water hose and blast the rotors all over close just with water... if you have a low psi pressure washer say around 1300psi even better... clean the rotors and then dry with a powered blower or any type to speed up the drying process - once you are done it will not squeak for 48hrs if done correctly.
Repeat regularly and that's it.
Squeaks gone.
BBHMM34.00
