      07-27-2019, 06:47 PM   #1
brad850csi
Drives: 16 F13 M6 Comp
F1x S63Tu turbo specs
I don't think I had ever seen this before - I knew the part code but never managed to find the turbine and compressor specs
https://www.boostunited.net/mgt2260d...0076-5011s-777
Compressor side:
Inducer ø 45,69mm
Exducer ø 60,00mm
Trim 60
A/R 0,66
Turbine side:
Inducer ø 50,00mm
Exducer ø 47,32mm
Trim 81
A/R 0,69
I had always guessed that from the part code is would be broadly equivalent of a normal GT22 series turbo but with a 60 series compressor which is exactly what it is. It does seem a bit strange to me that Garrett only do a GT22 series turbine with a 52mm compressor such as this turbo
https://www.garrettmotion.com/racing.../turbo/gt2252/
Then with a 60mm compressor you need to go up to the next size larger turbine.
https://www.garrettmotion.com/racing...turbo/gt2560r/
