      08-21-2022, 08:38 AM   #1
Chase1
Drives: 2014 bmw 650i coupe
F13 tires 21”
I have 21x9.0 +25 front and 21x11.0 +45 rear
What size tires should I run
Please help lol
I was thinking 305/30 in the rear but not sure if that’s too much
      08-21-2022, 12:23 PM   #2
Rsnk60 M6
Drives: 2016 BMW M6 GC
I ran 325/25/21 rear tires on mine
M6 Daddy
      08-21-2022, 09:10 PM   #3
Wheel man
Wheel man's Avatar
Drives: 2014 M6 GC
I would do 295/25/21 rear and 265/30/21 front if you plan to lower the vehicle. If not I would run the 305/30/21 in the rear. I attached a 21" tire chart below to help your math.
      08-22-2022, 11:35 AM   #4
Chase1
Do you think I could get away with a 295/30 in the rear? I’m having kw coilovers installed but I also want the meaty look
      08-31-2022, 03:17 PM   #5
Wheel man
Wheel man's Avatar
Drives: 2014 M6 GC
It's a 1/2" difference rear to front tire but it will work with the KW kit. I put 20*11 and 9.5 wheels on a friends M6 and ran a 315/30/20 in the rear. (As requested) I have attached a photo to give you and idea of the look. He was not happy with the look of the 30 series in the rear because it was so tall. But it doesn't rub or anything like that.
      09-01-2022, 10:27 AM   #6
machareus
Drives: '15 F06 M6 CP, '21 Alpina XB7
I have stock suspension and stock wheels (20x9.5 front, 20x10.5 back), but I opted for taller sidewall to better manage the terrible roads in my area. Went with 305/35-20 in the back and 265/40-20 in the front.
Those tires are 28.3" tall in the front and 28.4" tall in the back (pics below). The backs don't rub at all but the fronts experience a slight amount of rubbing against small protrusions in the wheel well liner. This only happens when the wheel is turned at a specific angle. I've seen no tire wear from the small amount of rub in about a month of driving them.
305/30-21 would be 28.2" tall, so with a 0.5" drop I think you may encounter an issue with fit.
ETA: 295/30-21 would be 28" tall, so that might be okay but it would be really close. The best match for front would be 255/35-21 which is also 28" tall, but I think with a 0.5" drop you would experience worse rubbing than my tires. Also my offsets are stock.
      09-04-2022, 09:05 AM   #7
Chase1
So if I were to run a 295/30 in rear what should I run in front? 🤔
      09-04-2022, 01:37 PM   #8
brad850csi
Drives: 16 F13 M6 Comp
One thing that nobody has realised yet is that Chase1 profile says 650i, but we are all talking about M6 setups.
The M6 setup is 20mm wider tyres front and rear with a completely different rear axle and wider front flares so any offset discussion isn't relevant between what we know as M6 people vs this setup.
The stock 650i tyres are only 26.8" front and 26.5" rear in height - they are 245/35r20 and 275/30r20.
With that stock height and your wheel widths I think you might be in a tricky spot - my thought would be 255/30r21 and 295/25r21 but the rear will be fairly stretched. I think that 265/30r21 and 305/25r21 might be a bit tall and you may start to struggle with clearance on the front suspension and wheel arch liner on turns but you might want to wander around the normal 6 series forums a bit more to look at what those guys are running
      09-08-2022, 08:25 AM   #9
machareus
Good point - hadn't noticed that.
OP could try giving Tire Rack a call. They have laser measured several cars and may be able to give advice on what could fit. They had not measured an M6 though.
