      02-10-2022, 03:57 PM   #45
CardinalFlyer
Drives: 2014 BMW 650i Convertible
Originally Posted by Opie55 View Post
As for night vision, there will be a camera mounted in your driver's side grill and a button with a moon icon on it in the row of buttons below the headlight switch. As for active sway bars/anti-roll bars, if you know what a sway bar looks like - a round steel bar about the diameter of a nickel that runs from one side to the other between your wheels - in cars with active sway bars the bar is not continuous - there is a motor in the middle about the size of a can of baked beans. If you have a smooth bar with no motor in the middle, then you don't have it. You can see it easily if you get on your hands and knees. Or you can decode your VIN online. All cars have active dampers standard, but if you also have active sway bars, the active damper item will not be separately listed, and instead there will be a line item called Adaptive Drive that includes both.
I looked. Guessing that I don't have it. That said, the sway bar isn't completely visible as it passes above the shielding on the bottom of the car.
      02-10-2022, 03:58 PM   #46
CardinalFlyer
Originally Posted by Qsilver7 View Post
You have all of these?
{night vision camera}
Nope. Guess I'm not as optioned out as I thought I might be. No complaints though.
