06-16-2019, 10:33 PM | #1 |
Rep 22
650i Xdrive Coupe Wheels
Looking for a perfect wheel set, that will fit the car and will fill up the gap without lowering, and make an a aggresive look
06-17-2019, 01:03 PM | #2 |
Rep 7,449
A "wheel set" is not going to accomplish this...if "wheel set" just means different wheels.
To "fill-the-gap" without lowering the car...will require using TIRES that have a taller sidewall than the BMW recommendation. And this will apply to all of the wheel sizes that work (18"/19"/20"/21"/etc). In regards to all of the original wheel/tire recommendations...they all have the same overall rolling diameter (within a small % if any at all)...thus the "gap" from the top of the tire to the bottom of the wheel well opening is the same regardless of the wheel size. As the wheel gets larger...the aspect ratio of the tire (the middle number) gets lower:
If you're plan is to "fill-the-gap" without lowering the car...you may want to check/verify if using a tire that has an aspect ratio that is greater than your existing or the BMW recommendation. But again, verify that this will not cause any rubbing of suspension parts. For example, instead of a 245/45/18 tire...try a 245/50/18 tire. Or instead of a 245/40/19 tire...try a 245/45/19 tire...or instead of a 245/35/20 tire...try a 245/40/20 tire.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 06-17-2019 at 01:08 PM.. |
Angry Ketchup61.00 |
10-01-2020, 07:10 AM | #4 |
Rep 12
10-10-2020, 09:30 AM | #5 |
Rep 40
I have some 20 in black wheels FS tires are about 70% still great tread on em and wheels are black Beyern Antler
2008 335xi Alpine White
2015 650i xDrive GC Black Sapphire |
Tags |
6series, coupe, rims, wheels |
