12-18-2020, 01:41 PM | #1 |
Rep 47
BimmerCode with a Tune
Just looking to do some simple coding for things like folding mirrors with locking and unlocking etc. Just curious, this will not affect my car's Tune will it? Just want to make sure before I plug this thing in and start changing things.
12-18-2020, 03:21 PM | #2 |
Rep 307
Consider bimmerlink and BimmerCode as diy route
12-18-2020, 04:17 PM | #3 |
Rep 76
It will not affect your tune at all
12-19-2020, 12:33 PM | #4 |
Rep 7,475
Bimmercode and other coding apps only changes parameters of the modules you select. If you had a “tune”...I would assume that was done to your DME/ECU that would affect the engine/transmission/throttle etc.
Folding mirrors and door lock/unlock and other coding parameters that are common...are done to the FRM/FEM/BDC/REM/HU-CIC/HU-NBT/KOMBI/JBE/SZL modules/etc. These modules have nothing to do with your engine or transmission. So the answer would be no..using Bimmercode or Carly etc should not affect an aftermarket tune if you use the apps correctly...and don’t brick the car or code so long without powering the battery that you drain the battery. If you get an understanding of the car’s communication bus...this should help ease your mind as to what is being done and to what control modules in the car are being affected. And the Bimmercode app tells you exactly what module you’re working on when making coding selections. An example of the various control modules can be seen in this topological chart below...which is probably more indicative of the communication bus used on BMWs from around the 2004-2010 era. BMW has since evolved some systems and created newer modules that control various new systems around the car:
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 12-19-2020 at 12:53 PM.. |
12-19-2020, 12:46 PM | #5 | |
Rep 307
Before you pay some modder to do a remote session and code your folding mirrors save your money and invest in the apps and explore it... share on here and folks can help ya with the basics... |
12-20-2020, 03:51 PM | #7 | |
Rep 7,475
And if you have a battery float/trickle maintainer-charger...consider hooking it up to the correct pos./neg jump start terminals in the engine bay so that you don’t run the battery down (unless you want to run the engine while doing it). Again, this is helpful (especially for the first time) when you’re learning how the app works and scanning through all the modules to see what is available for coding. If you haven’t watched any of the informative videos on YouTube (there’s some really good ones)...don ‘t freak out when the coding starts and you see warning/fault lights show up...this occurs as the coding is taking place and modules are being recoded & turning off/on.
