      10-28-2019, 03:14 AM   #1
Xx__xs
Drives: m6
Replacing CIC cable to Display Monitor
has anyone ever seen a DIY that shows how to replace the video output cable to the display monitor from the CIC?
61119185171 this part
      10-28-2019, 01:30 PM   #2
Qsilver7
Qsilver7's Avatar
Before scouring the internet for a replacement DIY...have you run that part number through one of the online part database sites to see if that part is used in your car?
If not, go to the following link, type in the last 7 digits of your VIN, then paste the part number you gave us into the part number (cross-reference) box to see if that part is used on the f06/f12/f13 6 series: https://www.realoem.com/bmw/enUS/select
      10-28-2019, 01:51 PM   #3
RagtagXMASTER
RagtagXMASTER's Avatar
119
Drives: 2013 M6
i did a full nbt evo retrofit into the car. to change the cable is not bad. it feels like your gunna break the monitor though....or at least mine did, comes out fine, just requires a lot of force to remove the screen imo.
why are you replacing the cic monitor cable. mind you there are 2 cables connected to the back of the cic monitor, one is power and the other is video signal. nbt integrates them into one cable.
      10-28-2019, 02:59 PM   #4
Xx__xs
Drives: m6
im getting the red screen, and cic shuts down by itself intermittently
      10-28-2019, 03:06 PM   #5
Xx__xs
Drives: m6
good call, i cant find it. how do i find the equivalent of it?
edit, i found it
61119339598
