10-03-2019, 07:02 AM | #1 |
Rep 49
BMW F06 springs
Hi guys. I see a lot of people rides on H&R Springs but there are also other well known companies. I found:
1) H&R - front 30mm rear 15mm drop 2) Eibach - front 25mm rear 20mm drop 3) AP - front 30mm rear 20mm drop 4) ST - front 30mm rear 20 mm drop What is wrong with those companies? Why everyone buy H&R if there are also other springs that offers more aggresive rear drop? |
10-03-2019, 07:09 AM | #2 |
Rep 121
Good question !!!!!
I've bought Eibach springs for 4 times and first 3 swaps have had enjoyable end, those last ones are still in my garage and waiting to get under my F13. Yes, different 'body' but still. |
10-03-2019, 01:13 PM | #5 |
Rep 315
There's also Megan Racing springs, which claim 1.25" (or 30/31mm) drop on all corners. In my opinion, BMW's in general usually sit a bit lower in the rear already, so perhaps that's why H&R is so popular.
I am considering doing a 1" drop in the front, but leaving the rears alone. |
10-07-2019, 03:17 PM | #7 |
Rep 659
sorry missed the reply
here https://photos.google.com/share/AF1Q...JLVVVaMDV4LURR some others here https://www.instagram.com/markprior2...ource=ig_embed
Current: 2017 M6 Gran Coupe
10-07-2019, 03:35 PM | #8 |
Rep 451
I wouldn't say anything is wrong with any of the companies. Different preferences.
Everyone doesn't want their car dropped that low (H&R) due to: - ground clearance - ride stiffness - H&R has a raked stance lower in front, small drop in rear - Cost |
10-13-2019, 01:01 PM | #11 |
Rep 2,444
Drives: 2018 630iGT sport
I’ve always gone with Eibach over the years.
10-15-2019, 02:18 AM | #13 |
Rep 121
10-15-2019, 07:25 AM | #14 | |
Rep 2,444
You need to be careful lowering a car on stock shocks too much by just changing the springs, because too much and the shock doesn't operate as it should, as its in a permanent state of compression, rather than being allowed return to it's normal "neutral" position; thus there is an increase risk of premature shock failure. Believe Alpina use (or certainly used to use) Eibach on stock shocks, hence that was good enough for me. |
10-16-2019, 06:51 AM | #16 |
Rep 121
10-16-2019, 07:33 AM | #17 |
Rep 49
Before h&r did separate springs for xDrive, in 2013 peoples with 4wd were running on 2wd version. Also for example Eibach sells the same springs(one part numer) for 650i and 650xi.
