08-04-2019, 08:16 AM | #1 |
Rep 279
Maintenance Items - Replacement schedule
Hi everyone,
Do you know when and/or at what mileage the following have to be replaced for a 2015 650xi GC? - Transmission oil - Brake fluid - Power steering fluid - Spark plugs - Engine air filter - Cabin filter Thanks Last edited by MichaelInChicago; 08-04-2019 at 08:29 AM.. |
08-04-2019, 08:43 AM | #2 |
Rep 2,904
Brake fluid has pretty much a universal replacement interval of every 2 years on any car. It's not because it wears out, but because brake fluid absorbs water. That both lowers its boiling point which can reduce braking in hard driving and can lead to corrosion in the system. If you buy it at the dealer, you will get regular DOT4 fluid in a BMW bottle - same fluid you can buy at any auto parts store. If you get it at a Mercedes Dealer you can get DOT4+ which has a higher boiling point and is not typically found in stores.
As for filters, I do that totally by sight because how dirty they get varies so much by how and where you drive. But 25K is probably a good rule of thumb. I think plugs are recommended at 40-50k. I'll do mine then regardless. I don't think you have power steering fluid? I think only convertibles still had hydraulic systems and that GC's had electric. |
08-04-2019, 09:27 AM | #3 |
Rep 199
The GCs still have hydraulic steering ; I think all xDrive 6 series got the Hydraulic steering, we haven't moved to electric yet
Source : Caranddriver 6 series specs |
08-04-2019, 03:30 PM | #4 |
Rep 2,904
Then where is the fluid reservoir located? I even looked on ebay at a '15 - same year as mine and where I have a PS reservoir, the GC has a blank spot. Maybe not an XDrive? Maybe its not a convertible distinction but an XDrive distinction? I'll have to look at some more pics.
08-04-2019, 08:04 PM | #6 |
Rep 1,698
Correct, the xDrive cars still had hydraulic steering. I'm a big fan of hydraulic steering, but it did limit BMW's ability to use systems like automated parallel parking as a result.
08-05-2019, 07:38 PM | #7 |
Rep 2,904
Regarding tranny fluid, you can search and read on this subject until you fall asleep. On these cars and other brands, there is a debate between it being "lifetime" or every 60k or so. Then there those who will say don't change it because the particles and gunk in it provide for closer tolerances and better operation, and that changing it will make things worse. I view those people much as I do those who believe the earth is flat or that we never went to the moon. The net (sane) result of research is that the maker, ZF, recommends every 60k. Works for me. That means I need to change my fluid in about 28k miles, or about 4 years from now.
No idea on PS fluid. Not very often. |
08-05-2019, 07:46 PM | #8 | |
Rep 1,698
