08-04-2019, 07:16 AM | #1 |
The Quiet One
1711
Rep 624
Quickjack for the 6 Series.
Haven’t seen this mentioned here, so thought I would.
As I found when I got my 6, raising via floor jack (even a very low profile one) is not straightforward. I took measurements and the Quickjack looked as if it would be a straightforward lift. It was. One does have to get a set of the pinch weld blocks for the rail is slightly shorter than the distance between the lift points. (An accessory from Quickjack). Worked like a charm. Couple of pics lifting my X5. First lift pic is at first locking position for a tire change. Second lift pick is at second lock position, full height at about 19 inches. I back up my full height lift with stands when I go under.
