      11-19-2018, 11:23 AM   #23
brad850csi
Drives: 16 F13 M6 Comp
Originally Posted by DDF200 View Post
Yes, the rubbing only occurs during tight/full turns. Sharp right turn causes left side rubs; sharp left turn causes right side rub.
It definitely is the edge/"corner" of the tire rubbing only on full/sharp turns. Shallow turns cause no rubbing.
Can you measure from centre cap to centre cap of your wheels? It should be 2851mm. Also post up a perfectly side on picture of the front wheel with it dead straight ahead?
      11-20-2018, 11:46 AM   #24
DDF200
DDF200's Avatar
Drives: M6 F12; 335D; i3
brad850csi you may be on to something here.
The driver side center to center measures 2878mm. That difference could easily contribute to the rubbing. Out of curiosity and to confirm my measurements were accurate (as possible) I measured the passenger side too. What's interesting is that the passenger side measures 2862mm. Not clear why both sides are not the same. Alignment issue?
I've included a pic of the wheel/tire as close to center/side as I could manage.
Thanks for a great suggestion!
      11-20-2018, 12:37 PM   #25
Havy
V8 addicted
Havy's Avatar
Germany
186
Drives: M6 Gran Coupť
To me it looks like the space/ gap between the fender and the tire is not equal and much closer in front.
gregmb14.00
      11-20-2018, 01:23 PM   #26
brad850csi
Yeah that looks way too far forward to me. Iím at an event for about 5 hours so I canít rush out and take a photo to compare but Iím sure that is wrong.
I suspect you have a suspension arm bent forwards.
      11-21-2018, 03:28 AM   #27
MelbourneFinn
Drives: 2017 M6 GC
Yes, or I wonder if incorrect caster could move the wheel that much forward. Interesting, appears that this is an issue on both sides as both measurements are off (if 2851 mm is what it should be), and both sides rub...
      11-23-2018, 04:15 PM   #28
DDF200
DDF200's Avatar
Is anyone able to share a side shot photo of their front wheel F12/F13 so I can compare to mine above?
      11-23-2018, 06:43 PM   #29
MelbourneFinn
Drives: 2017 M6 GC
Do these help? Not of a wheel only, but I think they show the wheel position in relation to the wheel well...
      11-23-2018, 06:45 PM   #30
MelbourneFinn
Drives: 2017 M6 GC
2nd photo, this time my previous F13
DDF2002.50
      11-23-2018, 07:30 PM   #31
brad850csi
I checked mine and it is about 2854mm for the wheelbase, slightly longer than it should be but possibly due to the angle of my driveway or something - definitely much closer to what it should be than your car is.
I found some press release photos showing that the tyre looks much more centred in every other photo
https://www.6post.com/goodiesforyou/...30_highRes.jpg
https://www.6post.com/goodiesforyou/...98_highRes.jpg
https://www.6post.com/goodiesforyou/...55_highRes.jpg
https://www.6post.com/goodiesforyou/.../P90089559.jpg
https://www.6post.com/goodiesforyou/.../P90089538.jpg
https://www.6post.com/goodiesforyou/...a/IMG_7404.jpg
DDF2002.50
      11-25-2018, 09:41 AM   #32
castlesteve
Drives: 2014 M6 Coupe
looks like you may have incorrect geometry, bent arm or something up there. That definitely is not normal
97 M3 Coupe -> 03 M3 Coupe -> 06 M3 Conv -> 14 M6 Coupe
06 X5 -> 07 Mini S -> 09 328 -> 12 X5 MSport
      11-26-2018, 09:04 PM   #33
Whipple
Whipple's Avatar
20
Yeah I seen the pic , thats definitely off center,I would take it to a BMW dealer and have them do a full check on you wheel alignment, I messed around with Lowering my Denali years ago,and the mechanic said to get the adjustment right so my tires donít wear wrong itís going to pull the wheel closer to the rear of the fender well , It rubbed on full lock , Iím just trying to say there probably is an adjustment to re center the wheel , Good luck
      12-05-2018, 05:05 PM   #34
DDF200
DDF200's Avatar
Final update on this issue!
Local body shop racked the car and determined:
1) there was some scrape/impact damage on the front bumper, underside, that was previously repainted
2) brackets holding the inner wheel well cover were bent on both sides
They fixed the brackets and no more rubbing.
Thanks to everyone who provided thinking and suggestions to solve this. Mystery solved.
gregmb14.00
      12-06-2018, 02:58 AM   #35
F06WINS
F06WINS's Avatar
Italy
98
Drives: F06 LCI & F32
Great to hear that everything turned out just fine.
      12-06-2018, 11:58 AM   #36
Havy
V8 addicted
Havy's Avatar
Germany
186
Thank you for the reply. I am happy for you that all is good now.
      12-07-2018, 07:37 PM   #37
Whipple
Whipple's Avatar
20
Thatís great that it wasnít anything more serious!
Tags
michelin, rubbing, size, tires
Copyright ©2000 - 2019, vBulletin Solutions Inc.
