      11-29-2018, 05:13 PM   #1
ace32x
Drives: 2014 alpine white M6 GC
M6 carbon ceramic pad replacements
anyone ordered pad replacements through these guys? advertised as OEM replacements, and also through amazon so easily returnable. service contract ended on my 14 last year and the front pads are about due up, figured this was worth investigating and swapping out over the dealership pricing
https://www.amazon.com/Sedan-Carbon-...Brake+Pads+Set
      11-29-2018, 10:32 PM   #2
Flying Ace
Flying Ace's Avatar
Drives: M6GC ZCP, X5d
Shows $650...OEM is running cheaper. https://www.turnermotorsport.com/p-1...f80-m3-f82-m4/
      11-30-2018, 12:05 AM   #3
mastatikle
Drives: 14 M6 GC Comp
Pretty sure M3/M4 uses different pads. I know for a fact they use different rear calipers so Iím assuming pads are different as well.
      11-30-2018, 01:56 AM   #4
Flying Ace
Flying Ace's Avatar
My whole point is, I know a FULL set is only $1000. So $650 for the front set sounds a bit expensive. But if you must... here is the front set directly from BMW of Lincoln. Under $600.
https://www.bmwdirectparts.com/oem-p.../?c=YT1ibXc%3D
      11-30-2018, 12:18 PM   #5
ace32x
good looking out with that one and the parts #
after some searching with the number found them for a little less on here aswell
https://www.bmwpartsupply.com/2014-b...nents-1931796/
$477
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
