      02-12-2020, 04:19 PM   #1
hart07
Drives: BMW 640i f13
What brake pad for 640i f13
My car maintenance said to me change rear pads in 1180 miles.
First what's the genuine bmw brand for the brake pads?
Then I just need to change the brake pad or I need to replace also the sensor brake and the
Spring brake too?
Thks
      02-12-2020, 06:19 PM   #2
DaveS86
Drives: BMW 640I
I much prefer the non BMW pads, specifically the EBC Red Stuff ceramics.....they produce so little brake dust it makes a massive difference to wheel cleaning! Just the one sensor need replacing, they are different lengths front and back with the back being longer, nothing else needs changing and you should get shims included. Also grease the bolt covered in the rubber boot, forgot what it's called.
      02-12-2020, 06:30 PM   #3
Opie55
Drives: '15 650i Convertible
Don't believe the sensor. It is a "dumb" system that is not measuring the thickness of your pads. If you cannot just look yourself, have someone you trust measure the remaining thickness of your pads.
      02-12-2020, 09:27 PM   #4
hart07
thks for all the ebc green stuff seems to be nice too.
      02-12-2020, 09:31 PM   #5
hart07
you have a tutto there to remove the caliper brake and paint it ?
cause the genuine caliper is bad and seems to get some rust too.
      05-28-2020, 11:26 PM   #6
hart07
Need a caliper tool to push the piston or not?
Got the new brake pads x4 and the new sensor
Just need to remove the wheel, unscrew the bolts to the caliper, remove the old brake pads
But the caliper piston need a tool to push it?
Thks
      05-29-2020, 06:07 AM   #7
DaveS86
Drives: BMW 640I
No, you shouldn't need a tool to compress the pistons, they should remain open enough to reassemble without. If not then just use a piece of wood.
      05-30-2020, 11:47 PM   #8
hart07
No need to grease any parts or other?
Just remove the wheel, two bolts for the brake caliper and disconnect parking brake, remove caliper and hang in on with a cord
Remove old brake pads change them and remove old sensor and put the new one.
No need to do anything else?
      05-31-2020, 01:05 PM   #9
DaveS86
Drives: BMW 640I
Depending on whether you are doing the fronts or rears you will have to tackle the handbrake piston, which is simply wound with a screw of some description. I normally grease the sliding bolt with the rubber boot on it as well and apply anti-seize to the caliper bolts and the backs of the pads. No different to most other brands.
      06-01-2020, 01:20 AM   #10
rasa bmw
ive got yellow stuff on my 330d,,and had red stuff on my 335d,,yellow a touch better in my eyes,,also a 15% discount code for ebc direct... EBC15DIRECT
