      02-14-2020, 05:53 PM   #1
xxTHIR13ENxx
Drives: F06 M6
Spark Plug Question
Hello,
I'm shopping for spark plugs and see on FCP the genuine BMW recommended plug listed but also a Bosch option at less than half the price:
Genuine BMW
Bosch
Under "Fitment", Bosch's plug lists M5's and M6's, so it should work, but question is, how different are these plugs, "really"?
I am not a fan of paying twice as much for name, but also don't want to run into any issues.
Is anyone with an M6 here running the Bosch plugs, and if so, how have they been holding up?
Car has the Comp. package, but otherwise stock power-wise.
Thanks in advance.
- Leo.
      02-14-2020, 06:05 PM   #2
RagtagXMASTER
RagtagXMASTER's Avatar
33
Drives: 2013 M6
Get the ngk 97506 1 step colder. On the website it does not say it fits. But it is a direct replacement.
The bosch will be the exact same as as the genuine bmw ones. Same manufacturer.
https://www.fcpeuro.com/products/bmw...plug-ngk-96987
      02-14-2020, 08:58 PM   #3
Flo1989
Flo1989's Avatar
29
Drives: M6 Gran Coupe
Originally Posted by RagtagXMASTER View Post
Get the ngk 97506 1 step colder. [/url]
+1 on the NGK's - Just ordered a set. Be sure to gap them if you're running a stage 2+ tune.
      02-14-2020, 11:30 PM   #4
xxTHIR13ENxx
Drives: F06 M6
Appreciate the replies, guys.
The car is stock, though. What would be the benefits of running colder plugs?
- Leo.
      02-15-2020, 08:40 AM   #5
EnVe46
EnVe46's Avatar
684
Drives: 14 M6 GC Comp
Im BM3 stage 2 91 octane tune, wanted to be on the mild side due to DCT clutches, and Im getting a hesitation/misfire up top in 3rd,4th,5th gear that was noticeable under WOT. I assume the stock plugs are my issue. After some reading seems most people are between .18-.22, is this accurate? What did you gap them too?
2011.5 E90 M3 ZCP
Interlagos Blau
      02-15-2020, 09:33 AM   #6
RagtagXMASTER
33
Drives: 2013 M6
- Leo.
a colder plug helps remove heat from the combustion chamber through he tip and body of the plug, in essence helping to reduce pre ignition and misfire conditions.
      02-15-2020, 09:39 AM   #7
RagtagXMASTER
33
Drives: 2013 M6
you should have the plugs gapped to .18-.22, change your plugs and coils most likely. if the issue is not resolved with that, do the injectors.
I believe they all come gapped stock to something in the .36 range. you should close the gap accordingly. stock plugs will work just fine though. i would suspect though that the car is blowing out the spark when you are misfiring.
I had the same issue when i bought mine and changed all of the plugs and coils, with genuine BMW parts, for piece of mind, completely fixed my issue.
as a rule of thumb if you are going to change coils or plugs, just do them all at the same time.
      02-15-2020, 09:56 AM   #8
EnVe46
EnVe46's Avatar
684
Thank you. I have bought the NGK colder plugs and will gap them to .20 per BM3 recommendation. Coils seem relatively cheap so Ill grab 8 of those are well.
2011.5 E90 M3 ZCP
Interlagos Blau
      02-15-2020, 10:47 AM   #9
Flo1989
Flo1989's Avatar
29
Has anyone been able to locate a gap tool that goes down to .020 other than the coin style? Which, seems to be a no-no for these type of NGK plugs. All the other gap tools Ive seen only go down to .025.
      02-15-2020, 12:25 PM   #10
RagtagXMASTER
33
Drives: 2013 M6
Go get a proper feeler gauge and the screw cap spark plug gapping tool. I will post a couple links to the tools once i relocate them
      Yesterday, 05:39 AM   #11
Mr. M6
FEEL THE POWER
Mr. M6's Avatar
Bahrain
75
Drives: M6 GC
2014 BMW M6 GC  [4.50]
https://burgertuning.com/products/bm...18598251823219
M6 GC CP + AMS CATLESS DP + AKRAPOVIC EXHAUST + MSR INTAKE=
      Yesterday, 11:33 AM   #12
Flo1989
Flo1989's Avatar
29
Thanks. I think I found what I needed..
https://www.amazon.com/Stainless-Fee.../dp/B081CSVMMN
This for actually measuring the gap
And this for re-opening the gap If I happen to make it too tight.
https://www.amazon.com/Powerbuilt-64.../dp/B002INZFZW
Originally Posted by Mr. M6 View Post
I like that a lot. If I planned on having to do this often I would invest in that tool. But Im hoping this is a one & done type of deal.
