      02-13-2020, 09:50 PM   #1
RagtagXMASTER
RagtagXMASTER's Avatar
33
Drives: 2013 M6
Eventuri Intake Refinishing
So i had the opportunity to get a set of original blue carbon fiber intakes made by Eventuri. sadly they were scratched a little, so i decided to refinish them
A lot was learned through this process. The intakes are well made, they used a nice thick epoxy, but it yellows from engine bay heat. at least the blue epoxy does. these tubes were actually the same standard black carbon fiber, but covered in a blue tinted epoxy!, this really makes any possibility possible for carbon finishes!
Here are some pictures of the refinishing process! I will also put up finished pictures once i complete the MAF tubes, i am currently trying to get the yellowing out of the CF, proving to be a very difficult process. Final option will be hydro dipping the tubes.
mikerx574.50
      02-14-2020, 07:01 AM   #2
bamfM6
Drives: 2018 M6 GC
Wow! Excellent work refinishing those intakes! Had no idea either that the epoxy gave the intakes their coloring vs the actual CF
      02-14-2020, 07:31 AM   #3
RagtagXMASTER
33
Drives: 2013 M6
I recently found out about epoxy finishing for things like countertops. It is a similar process when finishing the job. You can mix color into the clear epoxy and change results. Now i do believe Eventuris new carbon fiber all has a clear epoxy weave. I have a set of blue carbon intake scoops as well and the weave is different and is a slightly different blue. That leads me to believe they are now using a blue carbon kevlar mat and then sealing it with clear epoxy. I wish i could find a technique to remove the yellowing caused by the engine bay heat
      02-14-2020, 10:18 AM   #4
phan
Drives: E53 4.8is/E39 M5 SC'd/F06 M6
awesome job!
      02-15-2020, 11:20 AM   #5
spikespiegel
Drives: BMW M6 comp
nice! I was curious,d o these actually boost power? Cause it sure is expensive!
      02-15-2020, 12:23 PM   #6
RagtagXMASTER
33
Drives: 2013 M6
To be honest i doubt they will. The stock i takes are very good. I would say the only thing really wanted or needed are scoops to direct the air to the snorkels better. These i consider are primarily for looks.
