02-04-2020, 05:40 AM | #1 |
Rep 16
Drives: bmw 640i
help! - thumping in steering wheel
Hey guys, i have my 640i gran coupe and im experiencing weird noise / hitting my steering wheel and the noise comes from the behind of the tachometer/cockpit display. Its very hard to describe... I think it happens in slow speeds, in traffic jams. i cant define when its happening exactly but its annoying. I went through many of the threads here but couldnt find anything. Anybody could help?
02-04-2020, 09:57 AM | #2 |
Rep 2,906
Unless somebody else has experienced it, you are going to have to try harder to describe it. For example, does it happen all the time, or only when braking or turning or at certain speeds? You say you "think" it happens only at slow speeds. What do you mean you "think"? Is it so subtle that you cannot tell if it is happening at higher speeds? it Is it mostly a noise or mostly a feeling? Think something common it feel sounds like. If it's a noise, is is loud enough your passenger can hear it?
02-05-2020, 10:54 AM | #3 | |
Rep 16
Drives: bmw 640i
02-05-2020, 01:07 PM | #4 |
Rep 2,906
Does the motor that raises and lowers your steering wheel work as normal? Do all the different settings to direct air different places on your AC/heat system work correctly?
02-05-2020, 07:02 PM | #5 | |
Rep 248
02-12-2020, 02:38 AM | #6 |
Rep 16
Drives: bmw 640i
the steering wheel motor works without an issue. I turned off all clima - blowers, AC and still does it. I tried the old school trick with going all the way to the left with the steering wheel and hit brake few times and the the same to the right, repeated three times the pump some air to the SERVO. I drove just a little bit and it seemed like it helped, but have to drive more.
02-12-2020, 02:39 AM | #7 | |
Rep 16
Drives: bmw 640i
