      03-19-2020, 09:35 AM   #1
milestonemotors
Drives: F15, Grand national, S2000
BMW S63TU M5 M6 FABWORX downpipes install- Complete DIY
Full instructional Video (Including special tools, parts, torque specs and skill level) on how to replace the downpipes on an M6. Its the same procedure for an M5 and very similar to an N63. Feel free to comment opinions or questions.
Special tools:
Torque wrench, stubby 6 mm allen and multimeter, E-Torx sockets
Parts:
Downpipe to exhaust gasket ring- (2) 18307843213
Turbo charger to downpipe gasket ring- (2)
Downpipe to exhaust nuts- (4)18307597650
Torque specs:
Turbo to downpipe V-band-19mn
Downpipe to exhaust nuts- 21nm.
Skill level: (1 easiest, 5 hardest) 2
Fernando Osorio
President
Milestone Motors LLC
Website: https://www.milestonemotorspb.com/
Instagram: https://www.instagram.com/milestonemotors/
Facebook: https://www.facebook.com/Milestonemotorspb
Email: milestonemotorsllc@gmail.com
Linktree: https://linktr.ee/milestonemotors
Snapchat: Milestonemotors
Fabworx downpipes can be found here:
http://fabworxperformance.com/produc...ownpipes-2012/
Whipple262.50
HeyKC101.50
      03-19-2020, 04:03 PM   #2
Whipple
Whipple's Avatar
263
Nice job ! but you didn't show how to reinstall the 2 gaskets underneath on the downpipes and whats the torque value of the copper nuts that hold the mid pipe to the downpipe bracket.Ok I see the values in your list
Like you said I did mine with the DMEs in place bungee cords holding them open to the hood shocks worked great ,I didn't remove the PCV valves or the power steering reservoir,I was scared to remove the DMEs lol,looked like so many plugs
That was a good idea for the heat shield,I ran into that problem but I just cut the bottom of the cup off and reinstalled it just to look like its in there threaded the 02 sensor directly into the downpipe , I might get a turbo blanket for that spot anyway
Those bottom nuts I didn't know the torque value,so to compress the new gasket it feels like its getting tight and I was nervous I would snap one of the studs ,but I kept going equal on each side until they were snug you can feel them bottom out < i will retorque them when I change my oil next time
I never changed the gaskets in the turbo housing ,I didn't even know they were there ,I guess they just pop out and press new ones in there??
You didn't put the part number for these
Thanks for the vid Im sure it will help the DIY guy
Can you make a step by step vid on how to change the coil packs and spark plugs ? Thanks
      03-19-2020, 04:33 PM   #3
milestonemotors
Hi Whipple! Yes, When I worked at the dealer there were people who would leave the DME's in, Both ways work. If you take DME's out its a bit more comfortable.
I will provide those part #'s tomorrow!
Yes, they slide out easily- with a hand pick you can pull them out and pop the new ones in.
Whipple262.50
      03-19-2020, 04:34 PM   #4
milestonemotors
I'll work on getting that video for you the next time I have that job come through the shop.
Whipple262.50
      03-19-2020, 05:26 PM   #5
936F06
Drives: 2014 M6 GC
Mods sticky this
      03-19-2020, 06:05 PM   #6
Whipple
Whipple's Avatar
263
Yes that would be great help the community out with the vids , I know there is some specialty tools needed but you listed them with parts part #s to make it much easier, If you can do vids on all required maintenance stuff that would be awesome., Spark plugs and coil packs , Brake pads and brake fluid flush , engine oil and filter , transmission Full service , rear diff oil change , how to change antifreeze just a few that are on my mind
Thanks you
      03-19-2020, 06:58 PM   #7
milestonemotors
Keep the ideas coming! I'm all about taking instructional videos, I recently changed my niche at the shop to only servicing BMW's & MINI's so ill have a lot more time to shoot and edit.
      03-20-2020, 07:45 PM   #8
Jeffxxx
Part #18307553601
https://www.realoem.com/bmw/enUS/sho...diagId=18_0952
      03-20-2020, 08:00 PM   #9
milestonemotors
Wooop there it is! Strange how it doesn’t come up on ETK or real oem
      03-21-2020, 09:15 AM   #10
Szap12
2016 M6CP/Vorsteiner Aero/DME S3/Fabworx DP
Szap12's Avatar
Drives: 2016 M6CP
This is my car he installed the downpipes on! Great Job & Great Price Located in South FL!
      03-30-2020, 10:43 AM   #11
milestonemotors
Looking forward to making more performance video upgrades!
      03-30-2020, 10:44 AM   #12
milestonemotors
Looking forward to installing more performance upgrades!
      11-21-2021, 09:29 AM   #13
TinCanSailor
Fueled by Recycled Dinosaurs!
TinCanSailor's Avatar
630
Drives: F06 M6
Could someone kindly confirm that these two gaskets are the proper numbers for downpipe install.
18307553601
18307843213
Searches at various stores online either don't have it listed or claim fitment cannot be guaranteed.
Thanks in advance.
      11-21-2021, 10:16 AM   #14
arucano
arucano's Avatar
2014 BMW M6 GC  [10.00]
you should be able to reuse 18307553601. 18307843213 is the correct part number for the downpipe outlet (connection to the rest of the exhaust)
F06 M6 Grand Coupe CP
Sapphire Black Metallic
The drive is the destination
      11-21-2021, 11:17 AM   #15
TinCanSailor
630
Drives: F06 M6
Thank you clarification on the part reuse and the part number for reorder.
      11-22-2021, 01:56 AM   #16
Jeffxxx
I'd recommend replacing them regardless while you've got it torn apart.
      11-22-2021, 11:29 AM   #17
TinCanSailor
630
Drives: F06 M6
yeah, good point. Why risk the re-work over a few bucks.
Tags
bmw, downpipe, downpipes, exhaust, f06, f10, fabworx, s63tu
