12-19-2020, 07:50 AM | #1035 |
Rep 14,522
now that the main basement flooring is done i continued into the guest bedroom as well as the guest bathroom!
12-19-2020, 04:02 PM | #1036 |
Rep 4,365
Wanted a more custom storage solution for above our main fridge so just built one myself with removable dividers.
Before and after
2016 GMC Sierra SLT Z71 Premium Plus 4x4 2017 Harley StreetGlide • Denim Black • V&H Tune 2021 BMW x30i • Phytonic Blue Metallic • Fully loaded |
RickFLM410981.00 MaC-N54-E82464.00 vreihen1615280.00 IllSic_Design2124.00 hooligan_G016430.00 PoorLurker1136.50 Noneya251.50 |
12-31-2020, 03:40 PM | #1037 |
Rep 14,522
continued working on the basement! ripped out the existing vanity and toilet for the guest bathroom. had to repair the wall and used my hopper to respray the texture
also resprayed the hallway going upstairs from the basement due to a few holes and imperfections in the wall and finally started working on getting the door trim and baseboards installed
01-03-2021, 09:40 PM | #1039 |
Rep 14,522
just finished painting the basement guest bathroom. will start working on installing the baseboards, toilet and vanity sink tomorrow morning
01-04-2021, 06:06 PM | #1040 |
Rep 1,913
Drives: Here and There
Garage is slowly coming together... Put in new EVA foam floor today. Peg board for the tool bench should be coming in the next few days.
lsturbointeg9158.50 |
01-04-2021, 09:58 PM | #1041 | ||
F15 daddymobile
2350
Rep 3,510
01-04-2021, 10:20 PM | #1042 | |
Rep 1,164
01-05-2021, 12:37 AM | #1043 |
I'm Batman!
3948
Rep 1,477
That's awesome, mine is literally filled with random stuff as you can't reach the back of it unless you're 8 feet tall. Mind sharing where you got it from?
S55, 2JZ, M48.00 |
01-05-2021, 05:54 AM | #1044 |
Rep 4,821
Since you are also in Florida, let me ask... how do you keep the bugs and spiders at bay in that garage? I clean mine to keep them under control but you’ve got a TV out there and it looks clean enough to be an indoor room.
Current: 2018 SO/SS F83 ZCP
Gone: 2015 SO/SO F82 |
01-05-2021, 08:25 AM | #1045 |
Rep 4,365
I just made it myself from birch 1/2" plywood for the sides and 1/4" plywood for the dividers. All you really need is a saw, I just took 2 passes on the table saw for each divider slot as it was quick and easy. My standard kerf blade (0.125") was perfect at 2 passes to allow just a tad extra space for easy sliding in and out.
Kilabyte3948.00 |
01-05-2021, 08:46 AM | #1046 | |
Rep 159
I can say from experience with the x7 CB500/550/750's scattered around my garage.
2011 BMW 335i E90 - FBO w/ Pure Stage 2 Turbo on JB4 BEF
01-05-2021, 09:22 AM | #1047 |
Rep 11,843
Drives: MY24 G01 AW Msport
lawn and garage are my 2 important projects that need TLC.
i feel like hiring a professional to get it done right first time. |
01-05-2021, 10:34 AM | #1048 | |
Rep 1,913
Biggest nuisance for me honestly is lizards. I like them because they’ll eat the bugs that make it in there. But the damn things crap all in the garage. |
01-05-2021, 10:37 AM | #1049 | |
Rep 1,913
I just have too many hobbies |
01-05-2021, 11:05 AM | #1050 | |
Rep 4,821
We have a mosquito misting system around the front and sides of our house and all around the back patio to keep the mosquitos and some other pests away. This helps somewhat with the lizards and toads, but there are still some around. But I struggle with spiders in the garage no matter what I've tried. They seem to love the garage door openers and light fixtures that are right about our cars. We used to have the same problem with screen around patio until Hurricane Wilma solved it by taking the screen away.
01-05-2021, 12:11 PM | #1051 | |
Rep 1,913
Perimeter of house, eaves, and all openings get a concentrated liquid with my sprayer. Encapsulated Lambda-Cyhalothrin has been working great for me for years. I like this newer release ( https://store.doyourownpestcontrol.com/cyzmic-cs ). Stuff dries clear, so you could spray it in the corners in your garage, too. No real odor. Mix that in with your mister and you'd be set sans termites. |
RickFLM410981.00 |
01-05-2021, 12:46 PM | #1052 | |
Rep 159
I would build a scrambler out of it - those 350's are the perfect size with enough torque. Still good street manners if you put some dual sport tires on it or something that isn't uber aggressive.
spazzyfry1234358.50 |
01-05-2021, 01:17 PM | #1053 | |
Rep 1,913
Reason mine ended up getting torn down is I can't get the right cylinder to fire 90% of the time. Compression, spark, fuel, air...all is good. Time for a rebuild! And to not steer off course, this project will be done at my house! |
vreihen1615280.00 MaC-N54-E82464.00 |
01-05-2021, 01:20 PM | #1054 |
Space Shuttle Door Gunner
6430
Rep 5,309
We got a puppy in Nov, so the back yard got fenced in. Here is the fence and the pup!
12
01-05-2021, 01:23 PM | #1055 |
Rep 1,913
hooligan_G016430.00 |
01-05-2021, 01:31 PM | #1056 | |
6430
Rep 5,309
Thanks! |
