01-08-2021, 09:57 AM | #177 | |
Rep 6,196
01-09-2021, 09:01 AM | #178 | |
Rep 18,735
An oil analysis tells you how the oil performed under the last oil change interval. It is no better a predictor of oil performance looking forward than the manufacturer's recommendations. For fleet operators, an oil analysis may be beneficial, but fleet operations are much different than private auto operation.
F32Fleet3571.50 |
01-09-2021, 09:06 AM | #179 |
Rep 3,731
It detected a head gasket leak on my 05' F250 diesel with 225k miles on it (trace amounts of coolant in the oil). Saved my block/heads from any real damage. I might have not know it had an issue until I was towing something out in the middle of nowhere and had the motor overheat and lock up.
I was able to pull the heads off and replace the gaskets. It was worth $25 to me...... |
MightyMouseTech4337.50 |
01-09-2021, 06:22 PM | #180 | |
Rep 10,352
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line |
Efthreeoh17310.50 |
01-10-2021, 09:17 AM | #181 |
Rep 18,735
I've used BMW's oil all along for the E90. It started as Castrol, then switched to Pennzoil. Now I guess it'll go back to Castrol. Let's just hope they keep the bottles in the 1-liter size (which happened when BMW swapped to Pennzoil).
F32Fleet3571.50 |
01-10-2021, 10:10 AM | #182 |
Rep 1,823
What oil is in my M2? Dunno. Whatever BMW put in it 2 year ago. Last oil change March 2019. Next oil change March 2021 per BMW suggested use interval. iDrive tells me every morning I still have 10,000km left till next oil change. Had to top it off once in-between.
BMW Germany believe in every 2 years on 25,000km. So every ~15,500 miles. I do about 7,000 miler per year a few track days. Who am I to argue?
2017 BMW M2 German Spec
6MT, Driver's Package --> SOLD 2018 Camaro SS 1LE. Because race car! "Redline a day keeps the mechanics away" Last edited by 5.M0NSTER; 01-10-2021 at 10:19 AM.. |
F32Fleet3571.50 |
01-10-2021, 05:42 PM | #183 | |
Rep 2,665
Like getting specialized health checkups, you can find many people that never did them and still lived a long time. It doesn't mean the check is worthless, especially if you have a family history of a problem. I also haven't paid for a Blackstone but with some engines prone to certain problems, like the S54 (the family history) and it's rod bearings that have shown to wear through, finding the problem before there is a problem has value. We have seen engines following the manufacturers recommendations still have problems, especially regularly tracked cars.
2006 Z4M Coupe - Stromung exhaust, ZHP knob, stubby antenna, clutch delay delete
01-10-2021, 09:13 PM | #184 | |
Rep 42
01-10-2021, 09:28 PM | #185 |
Rep 706
Ummmm, just no! The oil oxidizing while sitting in the engine still requires it be changed every 6 months even while sitting! Lmao, unless of course it isn't yours, or you just don't care! And yes, you can get away with longer intervals, but it's a crapshoot depending upon the oil you use and the quality of the filter. Have fun!
01-10-2021, 11:52 PM | #187 |
Rep 2,350
Regardless of the warranty, bla-bla's and other manufacturer suggestion, the golden rule is:
* Replace the engine oil always at 10,000 km (6,000 miles) - maximum 15,000km (9,000 miles). If you love your car do it more often. A new oil will just help. * If you are making less km than that per year YOU MUST replace the oil once a year, even if the car sits in the garage. Don't be cheap an oil. You will pay dearly later.... |
01-11-2021, 09:25 AM | #188 |
Rep 3,548
Even then you can have issues. I'm a 5k miles / 1 year / whichever comes first person. I still ended up getting a new Valvetronic motor & eccentric shaft replaced. Only 29k miles on the car (2011). I have started to wonder if I actually drive it too infrequently because at least every other trip in it I make sure to drive 20 - 30 minutes to get it fully warmed up (no milky oil from lots of short trips).
01-11-2021, 09:38 AM | #189 | |
Rep 6,290
Shit just breaks over time it is what it is. I don't think it's because you're not driving the car enough lol. |
01-11-2021, 09:46 AM | #190 |
Sourkraut
29
Rep 12
That is actually possible. A BMW dealer once explained that to me:
Moving parts, all kinds of materials, tend to get "stuck" when you dont move them frequently. So when you then move them again, after a longer period of time, small bits and pieces will be teared off the surfaces. That way, leakage can and will happen. This applies to air conditioning compressors, for example. Also, rubber parts of all kinds will lose their ability to flex when they are not flexed for some time. In Germany theres even a word for that, Standschäden. Its a bit hard to translate it, "stand" means standing still and Schäden is damage. So you get the point: A car is made to be driven. Not to stand still. Also, the oil I use is Ravenol 0w40, replaced every 12 months (i'm at ~8000 miles per year) |
01-11-2021, 10:41 AM | #191 |
Rep 3,548
Generally there's always a thin layer of oil between metal surfaces i.e. crank journals and bearings. Obviously when running, but it stays behind afterwards. I wouldn't find it hard to believe that eventually however, gravity brings the metal parts together and gets 100% of the oil out of the way, at least in spots. My theory anyhow. Not sure if it's a week, a month, a year, but at some point (?).
01-11-2021, 11:01 AM | #192 | |
Rep 2,665
01-11-2021, 12:21 PM | #193 | ||
Rep 1,823
6MT, Driver's Package --> SOLD 2018 Camaro SS 1LE. Because race car! "Redline a day keeps the mechanics away" |
LogicalApex2025.50 David701567.00 |
01-11-2021, 12:39 PM | #194 | |
Rep 10,352
https://www.machinerylubrication.com...cation-regimes https://www.sciencedirect.com/topics...ry-lubrication
tracer bullet2411.50 |
01-11-2021, 12:44 PM | #195 | |
Rep 6,196
5.M0NSTER3353.50 |
01-11-2021, 12:45 PM | #196 | |
Rep 6,196
Put in Stabil, fill the tank, fill the tires to 50 psi, put a battery tender on it and forget about it till spring. |
01-11-2021, 01:06 PM | #197 | |
Rep 944
Drives: e92 335i, f22 m235i, e30 325is
I do my e92 at 7,500mi, half of the indicated interval. My e30 gets 1 per 3500-5k depending on driving. I use liquiMoly on both and both running strong at 122k miles and 320k miles respectively. |
01-11-2021, 01:12 PM | #198 |
Rep 2,644
Drives: 2019 BMW 540
I use Liqui-Molly 5w-40 along with a Mann oil filter. I did add Liqui-Molly CeraTech at 70k miles. I am at 72k miles right now. I have not noticed any difference. Idk If I'll use Ceratech again. But, I change my oil every 5k/6 months and buy an oil change kit off fcp (lifetime warranty on everything).
Oil change kit: https://www.fcpeuro.com/products/bmw...427566327kt-lm |
