      07-05-2019, 02:47 AM   #1
gjohnsen
Drives: 640D Xdrive
Ceramic brake pads
After warping several sets with oem rotors on different BMWs I decidet to install ceramic brake pads and a new set of rotors.
So far so good. Brake feels and brakes exactly the same as oem (as far as I can tell) with almost no brake dust. The wear on the rotors are now without deep grooves, just a layer layer of ceramic deposit.
Time will tell if they survive salty road and harsh driving condition. Rust is the main reason for rotor change in Norway. We don't brake enough in the winter
Strange thing, the front rotors fell right off after loosening the rotor screw. In the rear they were almost welded stuck.
      07-06-2019, 01:20 PM   #2
thebmw
Post Advisor
thebmw's Avatar
1631
I haven't noticed the warping that you have (maybe due to harsher climate?), but I have replaced my pads to a carbon/ceramic blend. Seems to be fine and far less brake dust.
      07-06-2019, 04:10 PM   #3
gjohnsen
Drives: 640D Xdrive
Changing OEM brakes are a 2500$ job at BMW in Norway. I drive on salted roads for 6 months a year. On every BMW i have owned i have warped the brakes. Except on my 2002tii 1975 model Which was my first car. I guess that cold climate is a major factor that causes warped brakes.
I hope ceramic pads will make a difference this time. I cross my fingers. And its a hell of a DIY job, when every screw is rusted tight. I used 4 hours changing the brakes front and rear on my car.
      07-06-2019, 09:56 PM   #4
thebmw
Post Advisor
thebmw's Avatar
1631
$2500 USD? That is quite high!
In the Chicago area, I can get all the rotors and pads for about $500. I can find independent shops to do the labor for about $250. The dealer is about $1500 total (twice the price for everything). I am guessing that there aren't a ton of BMW dealerships or options in Norway, thus causing the inflated price? Or is the monetary conversion the issue?
      07-07-2019, 02:30 AM   #5
gjohnsen
Drives: 640D Xdrive
Yes, the $ is very high against the NOK at the moment, and prices for labor are also high. Lots of BMW dealers around, but they charge exactly the same price. Have sometimes taken my cars to Sweden for repairs. Much cheaper.
The OEM brake parts are horrendous expensive for the F06, even in Germany.
      07-09-2019, 09:17 AM   #6
jjasonSU
Drives: 650i, NSX
Mine are warped (shake during high speed heavy braking)
I'll need to do this.
Was the install difficult?
      07-09-2019, 01:33 PM   #7
gjohnsen
Drives: 640D Xdrive
Its not difficult. But time consuming. Just follow online instructions and have all the tools ready before you begin. You also have an electric handbrake which has to be taken into consideration. Very easy job if you have done brake jobs before.
Check you have everything in hand before you begin. 18mm socket and 9mm umbraco are typical tools you don't have in your toolbox.
jjasonSU194.00
      07-09-2019, 09:20 PM   #8
SpooldYou
SpooldYou's Avatar
Drives: 650 XI Gran Coupe
I might attempt this myself also, do you have a list or links ?
