04-05-2022, 02:28 PM | #1 |
Rep 65
N63/S63 engines
Posted this over at the Convertible sub-forum without any success a few days ago so trying here instead.
Are the S63 engines in the M6 prone to the same problems as the N63 engines in the 650? I.e. heat resulting excessive oil consumption, timing misalignment, valve stem gasket leaks and injector failures etc? Or were those issues corrected in the S63? Any other caveats for the S63? Particular years to stay away from?
2007 BMW X3 2.0i E83
2012 BMW 650i Convertible F12 2023 BMW X3 Xdrive 30e G01 Gone: 2002 BMW 330i Convertible E46 2020 BMW X3 Xdrive 30e G01 |
04-05-2022, 08:16 PM | #2 |
Rep 432
There have been numerous reports of people having excessive oil consumption with the S63/S63tu motors. However, one way to fix this is switching to a higher weighted oil. For me, I run motul 5w40 and my oil never needs topped off in between oil changes (3k miles). As for the other problems you’ve mentioned, I haven’t seen any cases. But I’m sure if you dig deep enough you may find someone having had those issues in the past. Enough to categorize it as a“prone to” problem? - Probably not.
Henkan11.00 |
04-05-2022, 08:57 PM | #3 |
Fueled by Recycled Dinosaurs!
630
Rep 1,171
Drives: F06 M6
The M5 forums you'll find some hits on the rod bearings, injectors and valve stems for sure. I have a rebuilt engine and haven't had any oil consumption issues since then and I too change at 3k intervals. I also own a 550 with the N63 and can without a doubt say that I have never had that level of consumption problems with my S63.
04-06-2022, 02:42 PM | #4 | |
Rep 77
Henkan11.00 |
04-06-2022, 03:50 PM | #5 |
630
Rep 1,171
Drives: F06 M6
Aside from the oil consumption on my 2013 N63 550 we have had nearly zero mechanical problems and we are some where around 150,000 miles on it. Most of our issues have been door locks, soft close door or interior door handles getting sticky, trim/bezels and AC vents breaking inside the cabin. We may buy a refurbished long block for the car rather than buy a new one as the seats, body and paint have held up superbly.
05-07-2022, 05:45 AM | #7 | |
Rep 34
You can confirm it yourself by selecting the M6 on real oem and clicking through to the engine components, clicking the part number and seeing what other cars that part is used on. https://www.realoem.com/bmw/enUS/par...3-BMW-M6&mg=11 The only part I've found thats shared is the crank connecting rod. And in fact, even the block is different. |
05-14-2022, 01:22 PM | #8 | |
Rep 179
Drives: 2013 BMW ///M6 F13
05-14-2022, 01:24 PM | #9 | |
Rep 179
05-14-2022, 03:47 PM | #10 | ||
630
Rep 1,171
Drives: F06 M6
05-15-2022, 10:37 AM | #11 |
Rep 179
Do you know if any changes were made to the S63TU through the model years?
06-24-2022, 11:05 AM | #12 |
630
Rep 1,171
Drives: F06 M6
You will likely only see revisions to field replaceable parts. The F90 is a revision to the F1x. I know the pistons will fit the F1x and recently learned that the F90 oil pump is a direct fit. I wouldn't attempt a F90 long block swap but I am sure a very enterprising person with deep pockets could pull it off as folks have done LS swaps in M cars.
danielgmanm687.00 |
