05-31-2018, 04:38 PM | #1 |
Rep 17
Looking To Buy A Front Rim For M6!!
Whatsup guys, so since the m6 doesnt come with a spare tire and I changed my run flats to regular tires I'm looking to buy a 20" or 19" front rim for M6 in case a get a flat tire, I'm only interested in a front rim (9" width) since the back rim (10" width) won't fit in the front and front rim will obviously fit in the front and back ... let me know if anyone has a rim they want to sell it, rim doesnt have to be in great condition, just has to get me home in case of a flat tire, thanks
05-31-2018, 05:43 PM | #2 |
Rep 804
Why not just get a flat repair kit and pump? I have plugged tires multiple times while on the road. Beats ruining the whole day and getting the car towed. I got a flat, pulled over, plugged the tire and kept on going for 2 days until i got to a shop that installed a patch.
Flying Ace4984.50 |
05-31-2018, 08:50 PM | #3 |
Rep 11,891
Huh? You sure you're staying with same rolling diameter when you put the front on the rear?
06-01-2018, 02:19 PM | #4 |
Rep 17
what do you mean by rolling diameter? Im just looking to have a spare tire (not drive with it) that fits in the front as well as the back in case I get a flat so at least I can drive home few miles ...
SoCalM6, that is an option but only if u get a screw or nail in your tire but if your rims cracks or your tire has a tear and your solution wont help ... I feel that having a spare tire is the best, 10min and tire changed |
06-01-2018, 04:06 PM | #5 |
Rep 11,891
The rolling diameters or aka circumference (wheel + tire +air) for the front wheels and back wheels are not the same. You have a 35 spec front tire and 30 spec rear tire on a 20 inch wheel, meaning your fronts are overall longer in circumference or in other words "taller" when you stand a rear tire against a front tire.
Going straight, a taller tire will turn less times than a shorter tire over the same distance. What happens when you put a taller tire on the left axel and a shorter tire on the right axel is that your differential's gearing will have to accommodate for the difference, or in other words, it's going to fuck up your expensive $5k M differential in the rear or the open differential in the front. Perhaps I don't really know what the error factor is for mismatched diameters on the same axel. If I am wrong, someone please correct me. Anyways, your purpose will only cover you in 33% of your flat scenarios. If you hold a front as a spare, then it's only purpose is to be used when you have a flat front tire. But what if you get a flat in the rear? Also, you're okay carrying a 50 lb weight in your trunk the entire time?
08 Speed Yellow 911 GT3 Sharkwerks 12 AW/Cinnamon X5d Sports Pkg (retired) 14 AW/Beige M6GC ZCP, MPE, V2 steering wheel, vorsteiner (retired) 08 SSII/Black E90 M3 (retired) Last edited by Flying Ace; 06-01-2018 at 04:56 PM.. |
06-01-2018, 08:51 PM | #6 |
Rep 17
wow you make this sounds bad haha but I guess that make sens ... so what do you guys do if you are going on a little road trip, just carry flat repair kit and pump?
06-01-2018, 10:54 PM | #8 |
Rep 11,891
Do you know the tire sizes? I didn't mean to scare OP. I know staggered setup cars can run factory spares. But the spares are usually less than a certain percentage of difference in diameter.
06-02-2018, 01:58 PM | #9 |
Rep 17
front i got 275x35x20 and back i got 305x30x20 ... i was thinking to get 265/275 so I can use it in the front and back but after hearing all the shit that can go wrong with it i think Ill just buy repair kit and a pump haha ... plus you brought up good point with extra weight in the trunk ... just hate not having a spare tire, had some bad experience with my 3 series and aftermarket wheels (cheap wheels) ... anyway thx for the input guys, nice to know I can always count on fellow M owners
06-02-2018, 02:18 PM | #10 | |
Rep 1,293
06-02-2018, 04:19 PM | #11 |
Rep 582
I’m sure they had to make it close especially the Merc is AWD , I know if sizes are incorrect the AWD system goes bonkers
