04-12-2018, 01:00 PM | #23 |
Rep 832
04-12-2018, 01:03 PM | #24 |
Rep 832
Not really, i don't know any M6 owners here. Once in awhile i got to a BMW meets. PSI in Winter Park usually host one every couple of months.
04-12-2018, 07:05 PM | #25 |
Rep 131
04-17-2018, 01:55 PM | #26 |
Rep 181
Where did you find the idrive controller with the trim to fit? I am looking for one because the used ones sold do not have the plastic strip trim around...
05-20-2018, 01:07 PM | #27 |
Rep 8
09-16-2018, 03:52 PM | #29 |
Rep 318
you need to swap the trim pieces between the touch controllers for it to fill the void. its not very easy and it takes some time to get them swapped over the new touch controller has the trim under the silver dial and has 8 click holding it in place. the larger trim just stays clipped to the armrest. i will try and submit pictures to make it more clear
09-17-2018, 04:08 PM | #30 |
Rep 318
here are the pictures for the previous post about the different idrive controller trims, and how it will look after you swap them. In the first picture the left trim is the old touch controller trim you need. the right side is the new controller trim that you need to remove from the the new controller. it is a little challenging to do but possible. if you don't care about the new trim piece, break it out and toss it and just reuse your original trim.
01-11-2019, 11:50 AM | #32 |
Rep 684
04-05-2019, 01:42 AM | #33 | |
Rep 8
we met last year by the shop off of Orange. if you're still able to do upgrades, I'm definitely interested in paying you do the fit for my car. please let me know? I don't have your # or I would've text you awhile ago about it. thanks |
04-07-2019, 10:03 AM | #35 |
Rep 164
Great! Anyone here tried to retrofit iDrive 7.0?
06-05-2019, 03:06 AM | #37 |
Rep 3
Hi Nelson,
may I ask if in my 11/2011 CIC equipped 640d there is a way forward for a set-up with F15 touch screen, NBT EVO id6 and functional HUD with traffic and speed limits support? Thanks! |
11-04-2019, 10:32 AM | #40 |
Rep 73
Hey,
question about the weather and maps, i know you lose your connected drive features like remote unlock/lock but do you still have access to the weather on id6 and also how do you update the maps? I usually buy maps online on ebay and just load them in but the maps wont correct with the vin anymore right? so how do you get the fsc code to update? |
12-17-2020, 05:33 PM | #41 |
Rep 52
I am chasing if someone can give me a good answer, I have a M6 F06 with NBT-NBT Evo and it has the older screen. I want to just replace the screen with the newer looking one for a cleaner look. I don't mind the current system I have, can I just replace the screen? For example can I buy this and plug and play?
https://www.opuradio.com/bm-6550-933...-hu-p0251.html Cheers Chris Last edited by chrisveal; 12-17-2020 at 05:42 PM.. |
12-17-2020, 08:01 PM | #42 | |
Rep 333
Do a search for more examples/info also |
