      10-19-2020, 07:47 PM   #1
pepsih
pepsih's Avatar
129
Drives: f02, e24
Door Lock weird issue
Hi, im having an issue with the soft close door on the f06 gc.
The driver side door Does not lock,
Doesn't matter if i try to use the remote or the comfort access all doors locks and i can hear the "bip" EXCEPT the driver side door, and the "lock button" stays up. even if the lock button has been pressed you can still enter the car via the driver side door and the alarm will set off.
so basically to lock the door i have to press the lock button manually.
Same story when im inside and at certain speed all doors locks automatically except the driver side.
also on more little issue,
so basically the rear passenger side curtain (left side) does not work or work whenever she want to.
      10-19-2020, 10:26 PM   #2
DRock3d
Kraut Driver
DRock3d's Avatar
Drives: 2014 650i GC/2011 335is DCT
2014 650i Gran Coupe  [0.00]
2011 335is  [1.00]
2007 328i  [2.00]
Sorry man, you probably need to replace the door lock actuator. $500 from the dealer or around $200 if you can find one used. The lock motor burns up and while not impossible to service, I probably wouldn't try it.
      10-20-2020, 10:17 AM   #3
Russbmw
Russbmw's Avatar
Drives: 2018 630iGT sport
Can you lock it manually with the key, and is it stiff to do so? Similarly, does the pin move freely?
Just wondering if the guide rods have come misaligned or come out of their runners.
      10-21-2020, 05:59 AM   #4
pepsih
pepsih's Avatar
129
Drives: f02, e24
Yes i can lock it manually. basically now the door works the same way as the old civic lool
you have to use the key to unlock the car or the button to lock it. the remote, lock button (inside by the warning) and comfort acces does not work ONLY on the driver side door
      10-21-2020, 04:23 PM   #5
Angry Ketchup
Angry Ketchup's Avatar
England
61
Drives: 650i (F12)
I also have Soft-Close & Comfort Access... some many weird things have went wrong with the locking/unlocking of my driver's side door.
All were attributed to "Comfort Access sensors" in the handle itself. I've had one of them replaced twice now.
      10-21-2020, 07:45 PM   #6
DRock3d
Kraut Driver
DRock3d's Avatar
2011 335is  [1.00]
2007 328i  [2.00]
If you can lock by pushing the stick down and unlock by pulling the interior handle it is the lock motor in your door lock actuator. Me and itzjoker are having the same issue.
