      12-10-2024, 04:11 PM   #1
jaf30
Drives: F06 M6
2017 M6 complete power loss
I have a weird issue where occasionally my M6 completely loses power for 2-4 seconds before recovering. It feels like the car has jumped out of gear.
This only seems to occur when accelerating off a roundabout. It just so happens that it's the same roundabout every time, but this is likely a coincidence.
Things I've noticed when this happens:
  • After leaving roundabout, starting to accelerate to near wide open throttle.
  • Every time I've checked, the car has been in 3rd gear at about 3,500-4,000 RPM.
  • Engine holds its revs during the power loss.
  • Not traction control - no light on dash to suggest this.
  • No error codes in ISTA whatsoever.
Other than this one occasional issue, the car runs perfectly - No rough idle, smooth power delivery throughout the rev range. My current thoughts are that a clutch may be on its way out.
Not sure if anyone else has had a similar experience who could shine some light on this?
Car is at 71k miles. Fully up-to-date with servicing.
Thanks
      12-10-2024, 05:27 PM   #2
MeesterQ
MeesterQ's Avatar
26
Drives: F13 M6
When is the last time you replaced your transmission fluid?
      12-10-2024, 05:44 PM   #3
jaf30
Drives: F06 M6
Only (somewhat) recently taken ownership of the car, I don't think it's ever been changed so it's definitely on the priority list. I'll probably change it during the Xmas holiday period.
Is this a symptom of bad fluid?
      12-11-2024, 10:23 PM   #4
MeesterQ
MeesterQ's Avatar
26
Drives: F13 M6
I believe so.
I changed my trans fluid out at 25k miles.
Also would recommend taking a look at the clutch if a simple fluid swap doesn’t fix things.
Also check your diff fluid or change that out at the same time.
jaf305.50
      12-19-2024, 10:33 PM   #5
Cincinnatus
Drives: 2013 M6
Is it possibly the DSC kicking in too hard?
KurtsM5426.50
      01-03-2025, 11:15 AM   #6
KurtsM5
Drives: 2013 w/ DPs, BM3 stage 2
2013 F10 M5  [8.80]
Turn off DSC, turn on MDM, see if it gbreaks the tires loose(be careful!!!) If so, then Cincinnatus is right. DSC is preventing tire spin.
      01-05-2025, 05:14 AM   #7
jaf30
Drives: F06 M6
Presumably if it was DSC I'd get the flashing light in the instrument cluster?
I now have the service parts for the DCT, but still wating on the new oil to arrive.
Thanks
Copyright ©2000 - 2025, vBulletin Solutions Inc.
