01-25-2021, 04:13 PM | #1 |
Rep 20
Trickle Charger Install
Hey guys, picked up a Noco Genius5 today, did some searching here and on the M5 forum but couldnt find any direct answers on how to install this. Is the proper way to do it through the mounts in the engine bay? Any pointers would be GREATLY appreciated!
01-25-2021, 05:16 PM | #2 |
Rep 631
would recommend to install the eyelet connections under the hood and zip tie the lead to where you will hook it up to the charger. Leave the trickle charger loose and connect when required. I would not recommend to permanently mount the charger under the hood. You could use the bracket mounted in the engine compartment to hold the charger when you are using it.
F06 M6 Grand Coupe CP
