10-18-2018, 01:51 AM | #1 |
Rep 113
NBT EVO ID5/ID6 rtrofit with Touch Screen F12 F13 F06
I succeeded ID5 / ID6 and touch screen retrofit (bmw F06 GranCoupe)
EVO,ATM,CarPlay,TouchScreen ...It works perfectly. I will post some images here. Detailed work https://minkara.carview.co.jp/userid...5456/note.aspx Last edited by maron; 10-18-2018 at 02:19 AM.. |
10-18-2018, 02:02 AM | #2 |
Rep 113
Flying Ace4984.50 |
10-18-2018, 07:15 AM | #6 |
Rep 909
Hi and thanks for the information. Indeed I did the same by coding ID6_light and use it this way. My unit is older and is not touchscreen. I guess it will be hard to find "used" units to retroft dated 2018 as it's a bit too early for that. I agree gesture control also not a priority but if I should ever upgrade then I would try to get both.
10-18-2018, 09:13 AM | #7 |
Rep 113
I think that you can use the touch screen by code your EVO (ID5).
I have a unit for manufacturing in 2016 for spare and bench(Flashed to the latest firmware) I could use it when coded it and connecting it to the touch screen. Image attachment Or you can use it by flushing to the latest firmware. Last edited by maron; 10-18-2018 at 09:38 AM.. |
10-18-2018, 01:42 PM | #10 |
Rep 909
Has anyone tried Samsung (Android) screen mirroring on an ID5 / ID6 unit and can confirm that it works? If yes which APP (from Samsung) are you using?
10-18-2018, 03:00 PM | #11 |
Rep 11,891
does traffic information work?
10-18-2018, 04:12 PM | #12 |
Rep 909
For traffic i use RTTI from the Connected Drive Services which I find very up-to-date and precise usually. The big downside is as known that it will not show speed cameras / radars as other services/apps may do. But apart from this I say for me RTTI works perfectly. I am trying to screen mirror my A5 2017 Galaxy smartphone in order to see what apps I can use and how the whole thing interacts. I first need to check which coding options are needed for that to work. |
10-18-2018, 08:23 PM | #13 | |
Rep 113
Tested it with an old android tablet. I used APP called screen mirroring. |
10-18-2018, 08:24 PM | #14 |
Rep 113
Japanese units are equipped with traffic information as standard via FM(VICS) It presents real time traffic information, disaster information, speed regulation, torrential downpour area (displayed in red). |
10-19-2018, 11:39 AM | #16 | |
Rep 11,891
10-21-2018, 02:42 PM | #17 | |
Rep 909
https://f30.bimmerpost.com/forums/sh....php?t=1340698 But with NBT and EVO I have not heard of RTTI working without having a subscription. I personally find it worth it as for me is accurate and also pretty good and quick in calculating alternative routes. |
10-21-2018, 10:08 PM | #18 | |
Rep 11,891
10-22-2018, 01:37 AM | #19 | |
Rep 113
However, I can register on the connecteddrive site with this retrofit, and I can use all paid contents. ① Write an ATM CPS to the unit using an inexpensive adapter ※ connecteddrive contents is available but only map update impossible ② Match VIN of ATM and FSC VIN of unit ※All connecteddrive functions can be used. https://minkara.carview.co.jp/userid...5456/note.aspx |
10-22-2018, 04:20 AM | #20 |
Rep 909
Correct and the reason you need to do that is that otherwise both Remote Services and Concierge Services will no longer work. It would be like having a "crippled" unit.... Thus if I did this upgrade on my F32 car for example I would certainly want all paid services to work as they do know including the above-mentioned ones.
10-25-2018, 03:48 AM | #21 |
Rep 2
Hello,
Iam very interessted in this retrofit. My Car is an F06 640i from 09/2012. I have an CIC with combox. How much work is this retrofit? Is there any DIY? Thanks! |
10-25-2018, 06:46 AM | #22 | |
Rep 113
Used units may be obtained cheaply. My total cost is about $600 with all DIY done. If you have CIC installed, flash to ZGW02 Or you need a retrofit adapter. Other complicated wiring work will be necessary. |
