      04-30-2016, 07:25 PM   #1
Bobby_Drake
Bobby_Drake's Avatar
390
Drives: '16 X5M
Exhaust Flapper Mod
Got this from the M5 forum. A lot of guys were using zip ties and wires, but I found that using hose clamps to hold the flapper open were a lot easier. Here's the thread:
http://f10.m5post.com/forums/showthr...2#post19854452
Very happy with the sound!
      05-01-2016, 08:36 AM   #2
Acexxon
Drives: 2016 F06 M6 F87 M2
Thanks for sharing! Too bad I had already ordered Akrapovic system.... only if I had seen this a couple of week earlier...
      05-01-2016, 05:11 PM   #3
kris1858
kris1858's Avatar
2016 BMW M6  [10.00]
I went digital and got the exhaustmeister. You can set the remote to use one of the rear view mirror buttons to open and close the valves.
http://exhaustmeister.com/
Full Vorsteiner Aero Kit, ADV5.0 M.V2 CS rims, KW HAS kit, M Performance Exhaust w/ CF tips, CF Mirror Caps, CF Gear Selector Lever, CF Side Marker Gills, CF Front Grill, Dinan CF Intake, AFE CF Engine Cover, Stage II Dinan Tune, Exhaustmeister, Internal Escort 9500ci + Laser Shifters, Photosync window tint 65% windshield 35% windows, Full PPF xpel ultimate wrap, RK Autowerks noncatted DPs, reflector delete, various coding
      05-02-2016, 12:00 AM   #4
terrainx
Drives: bmw
Big difference make?
      05-02-2016, 04:40 PM   #5
mastermayhm
mastermayhm's Avatar
Drives: F90 M5
the exhaustmeister just opens and closes those valves?
e90 330 > e90 LCI N54 > e70 x5 50i > f12 M6 GC > f15 x5 50i > f90 M5
      05-02-2016, 05:19 PM   #6
kris1858
kris1858's Avatar
2016 BMW M6  [10.00]
Yes, take a look at the website, they have videos of before and after installation.
There is a definite increase in sound.
      05-02-2016, 05:27 PM   #7
kris1858
kris1858's Avatar
2016 BMW M6  [10.00]
Lightbulb
Yes, that is the exhaustmeister's function. It is a "plug and play" design.
Here is some info:
"How it works: The device is remote controller to keep the flaps functioning like OEM (off position) or at the push of a button, forces the flaps on both mufflers open, as if you were on throttle above 3000 RPM or as if you zip tied them open like many of us have (I did previously). At start up, the flaps are in the factory position and open at your command when you push the on button on the remote (there are 2 included for good measure) or on the garage door opener if you program it. This means every time you shut the car off it goes back to the stock position/control."
http://f10.5post.com/forums/showthread.php?t=953696
      05-02-2016, 11:48 PM   #8
Bobby_Drake
390
Drives: '16 X5M
How was the installation? I thought about this but Some guys from M5 forum gave negative reviews. So I decided to just go for the sure thing. DIY to keep the flap open. No drone anyways.
$7 for the hose clamps and 15 minutes of your time for installation.
      05-03-2016, 06:28 AM   #9
mjposner
mjposner's Avatar
898
Drives: 2020 Z4 40i
Do you need one or two exhaustmeisters? How is installed?
      05-03-2016, 07:39 PM   #10
kris1858
kris1858's Avatar
2016 BMW M6  [10.00]
Here is the quote from the same post. I had a BMW tech install mine and he did it in 10 min. You will only need 1 exhaustmeister because there is one plug-in that opens and closes both valves.
Install Instructions: "Follow the instructions on their site. Very straightforward, took less than 10 minutes. They even have pictures if you need them. Basically pull the trunk carpet back on the left side after removing the clips, disconnect the factory plug, connect the ExhaustMeister plug to the factory connector and the factory wire to the other cable on the ExhaustMeister. Then take the white ground wire and connect it to one of the bolts in the area. I used the one pictured. Leave the blue wire alone, its the antenna. Put the carpet back. That's it."
No issues since I had mine installed last July.
Hopefully the website will be up soon for installation instructions.
      05-07-2016, 01:22 PM   #11
SouthlakeM6GC
Drives: 2015 M6 GC
I just received my exhaustmeister last week and started to install it today, however, the installation pages on the website are not found. Actually the pics to support the install. Does anyone have the step by step pics or the pics of the module for installation. I hate to mess with a $130,000 car in the blind when I have nominal mechanical experience.
      05-07-2016, 05:02 PM   #12
JMHP
Scotland
Drives: BMW i8
Just did mine today after waiting weeks for the instructions to go back up, finally thought what the heck!
Popping the carpet fasteners is pretty straight forward, knowing where the module is located is the key bit you need to know (per your question).
I've an F12 - it is literally upper side of the left rear wheel arch... When you pull the carpet back it's the only thing up there. Using the pic from the link below you'll see the connection type that matches you EM unit.
http://f10.5post.com/forums/showthread.php?t=1111529
Hope this helps.
Ps carpet can be stiff, but just work at it!
      05-09-2016, 07:18 AM   #13
lunden
Drives: BMW M6 F13 800RR
If you have it in sport plus or M mode it will have flaps open at all times - at least for European cars lol
      05-09-2016, 12:37 PM   #14
Bobby_Drake
390
Drives: '16 X5M
I thought that is not the case even in sport+ mode. At certain RPMs, the valves do open up but I was under the impression that even european cars do not have the valves open at all times.
      05-09-2016, 01:41 PM   #15
mastermayhm
Drives: F90 M5
so what exactly is the point of this exhaustomatic ? why is this any better than zip tie or clamp?
      05-09-2016, 08:51 PM   #16
SouthlakeM6GC
Drives: 2015 M6 GC
I ordered it so I can control the sound. I wake up early to work out and don't want to wake up all of the neighbors. After 8am I plan to have the valves open all the time.
      05-11-2016, 03:12 AM   #17
MP
Switzerland
24
Drives: M6 Gran Coupe
Sorry for asking again but when do normally flaps open? I have Comp Package and no mods. Do they always open above 3000 rpm? Is it driving mode specific? Thanks
      06-01-2016, 06:23 PM   #18
hjs1971
Drives: 2017 x5m, 2012 m6 convertible
Just installed mine today, very easy, 10 minutes tops. There is a definite increase in sound but not a lot, it's not going to make your car sound like it has a race exhaust. It's basically the same exhaust note, just a little deeper and a little louder. As an aside, mine got really hot today, maybe it was just the Florida heat in my trunk but the box was very hot to the touch, anybody else have that issue???
2013 Alpine White X5 3.5xdrive Daily driver.
2012 San Marino Blue Metallic M6 convertible with silver stone interior. No mods. Weekend cruiser.
      06-02-2016, 01:49 AM   #19
lunden
Not sure about US cars, but EU cars: When car is in sport plus or M1/M2, the valves are open
      06-18-2016, 12:59 PM   #20
mjposner
mjposner's Avatar
898
Drives: 2020 Z4 40i
What size hose clamps were used. I did zip ties to test. Definitely louder, especially in my garage.
      06-19-2016, 09:36 AM   #21
Niklas
Niklas's Avatar
9
Drives: San Marino M6
wired mine open on my comp back exhaust and man such an awesome difference on the pops and overall sound especially on the downshifts and once the exhaust is warm, much more brutal! Can highly recommend
      06-20-2016, 01:11 PM   #22
Bobby_Drake
390
Drives: '16 X5M
Can't recall the exact diameter. I know I needed something with a diameter of about 2.5" or greater. band width is 10mm.
