07-20-2019, 06:40 AM | #1 |
Rep 279
Brake pad replacement
The car is telling me it is time for a rear brake pad replacement, so do I replace just the pads or do I have to replace the discs as well (when I was in the garage about 2 months ago, they also told me I had a few months left on my pads but said my discs were good; I have 51,000 miles on the car).
The reason I am asking this question is that a few years back, I replaced just the pads on my 4 series GC and the brakes squealed from that point forward, and I was told by the garage that changed them that you must change the discs as well when replacing pads as squealing will most likely happen if you do not change them both at the same time. Is that correct or was the garage trying to do unnecessary work? Thanks |
07-20-2019, 07:39 AM | #2 | |
Rep 302
Drives: 2017 BMW X5M
07-20-2019, 01:07 PM | #3 |
Rep 60
The only way to tell is to measure the rotors. 24mm when brand new, and 22,4 mm minimum thickness. (EU Version- not sure if US is the same)
Use a caliper tool to take the measures. https://www.homedepot.com/p/Steel-Co...0902/301118028 |
07-20-2019, 03:04 PM | #4 |
Rep 1,832
They may have squealed because of debris between the disk and pad. I changed the pads all round on my 6er this year and they are quiet. Just make sure to clean everything thoroughly with brake cleaner prior to assembly and apply the anti squeal paste as per BMWs directions (check the newtis.com site). The rear pads are in floating caliper so it's not a particularly challenging DIY.
Also note that the electronic park brake needs to be put into service mode before attempting changing the pads. Easy to do with software tools, a little more challenging without. |
07-20-2019, 04:11 PM | #5 |
The Quiet One
1713
Rep 624
Hugo, can you speak more on this.
2013 X5 LCI 35i Jet Black / Black SensaTec - The Horse 2013 X5 LCI 35i Space Grey Metallic / Black Nevada // Sport Pkg - Daughter’s 2013 X6 M Sapphire Black Metallic / Black Merino \ Carbon Fiber - Son’s |
07-20-2019, 10:12 PM | #6 |
Rep 1,832
Sure. The electronic parking brake uses the rear brakes to function. It does this by compressing and releasing the brake pads when actuated.
In order to change the pads you need to fully retract the electronic park brake. This is easily done through software like Autologic or Rheingold/ISTA or manually by disassembling the actuator housing on the caliper. Here's a video on the latter: https://youtu.be/Ljq4ATPorXM |
jjasonSU194.00 |
07-21-2019, 04:51 PM | #7 | |
The Quiet One
1713
Rep 624
Much appreciated. Craig
07-21-2019, 10:50 PM | #8 |
Rep 1,832
07-22-2019, 11:51 AM | #9 |
Kraut Driver
59
Rep 624
Drives: 2014 650i GC/2011 335is DCT
Powerstop from Rockauto is the way to go
07-23-2019, 10:09 PM | #12 |
Post Advisor
1635
Rep 1,698
