06-10-2020, 04:49 PM | #1 |
Fueled by Recycled Dinosaurs!
630
Rep 1,170
Drives: F06 M6
Sent my M6GC to finishing school @RKAutowerks
So my car was being a bit of a misbehaver and the engine failed not long ago. I have been dealing with a lot of hand wringing on what to do and who to do it with etc.
After a lot of web based recon and making friends with others that were having work done I was finally able to have this happen two days ago. Appreciate the folks at RK Autowerks on helping out of a failed uship transport problem at the last minute. The car was next to impossible to get loaded on the truck due to the dead weight, the slight incline of the road and the sag of the lift gate but thanks to my son and a some tremendously kind neighbors that showed up out of no where we got it in and on the road. Things are finally starting to take a turn for the better. When it gets back I am taking neighbors and now new friends and my son out for a joy ride and lunch and later that night I am taking my wife back out for that dinner that I was taking her out on the night the car died.
06-10-2020, 04:56 PM | #2 |
630
Rep 1,170
Drives: F06 M6
Thankfully it was dry that day!
06-10-2020, 10:04 PM | #3 |
Rep 111
Still a little bit of faith in humanity left!
I always chuckle when I see the inside of these transport trucks which look like crap that house $100k+ cars. Same thing when I got mine delivered, looked inside and it was super junky and actually leaking a bit of water, but inside there was a Porsche gt2, Ferrari 488 and a 60s vette convertible. |
Flying Ace4984.50 TinCanSailor629.50 |
06-11-2020, 06:40 PM | #4 |
630
Rep 1,170
Drives: F06 M6
Just got word my baby has arrived!
06-16-2020, 12:31 PM | #5 |
630
Rep 1,170
Drives: F06 M6
getting better by the day.
06-16-2020, 02:27 PM | #6 |
630
Rep 1,170
Drives: F06 M6
and it is out...
DRKNTM615.50 |
06-16-2020, 05:01 PM | #7 |
630
Rep 1,170
Drives: F06 M6
another layer peeled away from the onion engine
DRKNTM615.50 |
06-16-2020, 06:29 PM | #8 |
630
Rep 1,170
Drives: F06 M6
That is a beautiful sight to me.
06-17-2020, 11:03 AM | #9 |
Rep 582
Wow nice! He has prebuilt engines ready to go?
What are the upgrades to the engine ? I would hope forged pistons and connecting rods and all new upgraded crank and connecting rod bearings.?
MMMM6GC275.00 TinCanSailor629.50 |
06-17-2020, 03:31 PM | #10 | |
630
Rep 1,170
Drives: F06 M6
Below is the details on the engine rebuild. S63 standard rebuild Replacement of all wear items Upper crank bearing Lower crank bearing upper guide bearing Lower guide bearing upper rod bearing green lower rod bearing red collar screw stetching m11 collar screw aligning m8 collar screw secondary m8 head bolts head gasket profile gasket 1-4 profile gasket 5-8 valve cover gasket 1-4 valve cover gasket 5-6 cyl 1-4 chain and rail slide rail 1-4 upper slide rail 1-4 chain tensioner cyl 5-8 chain and rail guide rail upper slide rail chain tensioner vanos bolts central chain guide upper oil pan gasket lower oil pan gasket front timing cover gasket front main seal rear main seal dowel sleeve oil return cover Water pump seal valve stem Seals
06-17-2020, 03:38 PM | #11 |
630
Rep 1,170
Drives: F06 M6
New engine mated to the trans.
06-17-2020, 04:42 PM | #12 |
630
Rep 1,170
Drives: F06 M6
up, up and away...
06-17-2020, 04:43 PM | #13 |
630
Rep 1,170
Drives: F06 M6
damn it, not sure why it is turning them sideways.
06-17-2020, 06:00 PM | #14 |
630
Rep 1,170
Drives: F06 M6
I've got the joy, joy, joy down in my heart!
06-17-2020, 06:08 PM | #15 |
Rep 582
Nice man congrats, you should get the car back soon ,that was a pretty fast turn around
06-17-2020, 07:56 PM | #16 |
630
Rep 1,170
Drives: F06 M6
TY. My heart is pounding out of my chest with excitement right now. My son and I are taking a road trip this weekend to tow it back ourselves. I could have had it transported for about the same but I need some windshield time with my boy.
06-17-2020, 09:59 PM | #17 |
Rep 628
drive it back. that is exactly the break-in distance......
06-18-2020, 07:11 AM | #18 |
630
Rep 1,170
Drives: F06 M6
The thought has crossed my mind but the folks at RkAutowerks is going to put about 500 on it before turning it over just to me to make sure it is absolutely gold seal of approval good to go. Plus I need tires for it which I plan on getting once I get it back home.
I'll probably find a school zone with a crap ton of speed tables and potholes in it to help me resist the urge of getting carried away during the remainder of the break in period
06-18-2020, 10:07 AM | #19 |
630
Rep 1,170
Drives: F06 M6
All done in under 2 days!
06-18-2020, 11:06 AM | #20 |
630
Rep 1,170
Drives: F06 M6
Honestly I think it need a detail a lot more than the engine as it sat for a while. Stock rebuild, 24/24 warranty and a detail all for a 1/6th of what the dealer was going to charge me. Thank you Raza, Mike and Team @RKautowerks!
Flying Ace4984.50 |
06-18-2020, 01:02 PM | #21 |
Rep 99
Mind telling us what it cost to have the stock rebuild done?
God forbid anyone ever needs one |
TinCanSailor629.50 mikerx5461.00 |
