04-25-2008, 10:23 AM | #1 |
not afraid to call it like I see it
32
Rep 316
ZR-1 Specs are out...638HP/604TQ
Official GM announcement snippets, for easy future reference:
**************************************** ***************** CHEVROLET ANNOUNCES CERTIFIED POWER RATINGS FOR THE NEW CHEVROLET CORVETTE ZR1: The 2009 Chevrolet Corvette ZR1 Powertrain has completed SAE certification of the ZR1's supercharged LS9 V-8 and the results exceed the estimate: 638 horsepower (476 kW) and 604 lb.-ft. of torque (819 Nm) ...output is nearly 103 horses per liter, or just about 1.7 horses for each of the engine's 376 cubic inches. ...unquestionably the most powerful automotive production engine ever manufactured by General Motors ... enables... top speed of more than 200 mph. The Corvette ZR1 goes on sale this summer. Fuel economy testing has not been completed... will be the most fuel-efficient 600-plus-horsepower car on the market. ...engine is hand-built by specially trained technicians at GM's Performance Build Center in Wixom, Mich. Endurance and reliability testing have shown the engine to be robust and low-maintenance, just like other engines in the small-block family The key enabler of the LS9's performance is the industry's first production application of a new, positive-displacement Roots-type supercharger... 2.3-liter displacement ensures adequate air volume at high rpm. Maximum boost pressure is 10.5 psi (0.72 bar). ...integrated charge cooling system that reduces inlet air temperature for maximum performance. LS9 details Aluminum cylinder block iron cylinder liners finish-bored and honed with a deck plate installed Forged steel crankshaft with a nine-bolt flange Titanium connecting rods and forged aluminum pistons Stronger, rotocast cylinder heads 2.16-inch (55 mm) titanium intake valves 1.59-inch (40.4 mm) hollow-stem, sodium-filled exhaust valves Camshaft with 0.555-inch (14.1 mm) lift for excellent idle and low-speed driving qualities A dry-sump oiling system with 10.5-quart (9.9 liters) capacity Integrated oil cooler and piston-cooling oil squirters Specifications LS9 6.2L SUPERCHARGED V-8 Displacement (cu in / cc): 376 / 6162 Bore & stroke (in / mm): 4.06 x 3.62 / 103.25 x 92 Block material: cast aluminum Cylinder head material: A356-T6 rotocast aluminum Valvetrain: overhead valve, 2 valves per cylinder Fuel delivery: SFI (sequential fuel injection) Compression ratio: 9.1:1 Horsepower / kW: 638 / 476 @ 6500 rpm Torque (lb-ft / Nm): 604 / 819 @ 3800 rpm Fuel shut-off (rpm): 6600 Recommended fuel: premium required Exhaust manifolds: stainless steel Main bearing caps: forged steel Crankshaft: forged steel Camshaft: hollow steel; 0.555-in (14.1 mm) lift Connecting rods: forged titanium Valves: intake: titanium, exhaust: hollow steel Valve lifters: hydraulic roller Supercharger: R2300, four-lobe "Roots" type (2.3L) Additional features: piston oil-spray cooling; direct-mount ignition coils; 11-rib accessory drive |
04-25-2008, 10:53 AM | #3 |
Bored at work....
893
Rep 5,397
Not bad.
Grey Matter:2008 E92 M3:608/425. SG/PS SOLD!
Dark Matter:2015 F80 M3:495/505. SOLD! Anti Matter :2016 F82 M4 GTS What next?!? A 2022 M235i GC- I must be getting old |
04-25-2008, 11:44 AM | #5 | |
Smiling Politely
1383
Rep 29,118
its gonna be nuts, interior still looks like shit tho
04-25-2008, 01:23 PM | #6 |
32
Rep 316
04-25-2008, 02:21 PM | #7 |
If You Aint First, You're last !!!
91
Rep 2,509
umm. i'd like to take one home.
08 BMW BSM 335i 6MT (Sports, Premium, NAV, PDC, AS, IPOD, HD Radio, Rear Sunshade, OEM Alarm) Angel iBright V3, Luminics Fog Bulb, Turbo Tuner, K&N Drop in Filter, Dinan Exhaust, Dinan Pedals, Vorsteiner CF Front Lip, and CF Rear Diffuser. Ordered:08/25/07 Started: 09/09/07 Finished: 09/14/07 On Ship: 09/15/07 Arrived: 10/08/07 Delivered: 10/10/07 |
04-26-2008, 01:33 AM | #9 |
Rep 12,445
Something about this just isn't appealing to me...
Past: '08 E92 335i|ZPP|ZSP|6AT
Past: '15 Mustang GT|401A|PP|6MT Current: '20 Shelby GT350|6MT |
04-26-2008, 01:27 PM | #10 |
Rep 10,587
what? I'm hooked....I want one bad. Not going to get one now, but I would love to have it.
sick car. Just sick. Rock everything on the road except MAYBE an enzo and koenigsigg (sp?). A few tweaks and it'll just be a killer. check out this video of high speed testing. the other cars on the track look like road blocks! The car hit a VBOX indicated 206mph on this test.....this was a GM test too. http://www.corvetteconti.com/blog/wp...r1-ncm2008.wmv yup.....not appealing
04-26-2008, 01:54 PM | #11 |
Rep 1,007
Any car that can accelerate from 130mph to 200mph that fast is pure beast.
That's similar to an e90 going from 30mph-100mph. ________ Sohc V6 Engine Last edited by HappyG; 03-08-2011 at 09:12 AM.. |
04-26-2008, 04:30 PM | #12 |
Rep 3,200
Then you haven't seen it, it's actually nice.
328xi Coupe, Montego Blue on Black with Alum, Step, Sport, Premium, CA, PDC, Cold Weather (Damn Pennsylvania winters)
Current Mods: Heavy right foot - Planned Mods: Lightweight right foot |
04-26-2008, 04:36 PM | #13 |
Rep 849
640hp stock! Holy shit!
I love the car, but... RWD + light weight + 640 hp + non-proffessional driver = ONWED!!!
08 E92 335xi Space Gray 6AT - PROcede V2 12.8 @ 111 mph
04-26-2008, 05:34 PM | #14 | |
I am Gundam
189
Rep 1,211
Only question I have is why was there a freaking semi on the racetrack? |
04-26-2008, 05:35 PM | #15 | |
Rep 10,587
yup! I hope they put in a VERY good traction control system. We are going to see some bad accidents with these cars. However people will crash doing what they love!
04-26-2008, 06:07 PM | #16 | |
Rep 12,445
I'm sure that if I was ever to get behind the wheel of this thing I'd be in love, but until that day I'm just not "into" it.
04-27-2008, 08:53 AM | #17 |
Rep 23
From what I heard the car is computer limited to 210mph and that the car actually reached 208mph. The 205 reading was the average of the runs.
More info Curb weight (full gas tank and all fluids) 3324 lbs Dry weight 3155 lbs |
04-27-2008, 09:35 AM | #19 |
Rep 2,382
Chevy really wanted to hit one out of the park with the ZR-1 and man did they ever. This car is unreal. I'd love to just hear one in real life.
2016 F80 ///M3 [YMB / Black Full Merino / Carbon Fiber Trim / DCT / Everything] I picked DCT because I want to be more involved in my un-involvement.
04-28-2008, 02:30 PM | #20 |
Rep 10,587
I cant wait to see one of these on the road or at our next MIR track rental. I know this one guy that will certainly buy one. At the last rental he showed up w/ 3 different car trailers. Inside was a GT2 w/ tuning, a stock C6 Z06, and a tuned Ford GT w/ 700hp. He simply has to buy this car to complete his collection of ridiculously fast modern muscle.
fyi-he ran 11.0x w/ his bone stock Z06, 11.2-11.3 in the GT2.....he can DRIVE. no matter what he tried, he couldnt get the GT into the 10's...I remember that making him really mad.
04-28-2008, 02:53 PM | #21 | |
32
Rep 316
