      07-23-2021, 03:15 PM   #45
Coi
Drives: 21 X3 M40i, 07 Z4MR
Originally Posted by pikkagtr View Post
Part of your post is correct
However my point is you can only do a swap if the engine was available for the chassis of the car
So no k24 legal swaps I to an EG civic
Even though it would literally cut emissions in half
CARB legal engine swaps are definitely possible as long as emissions equipment isn't modified. Engine can even be from a different manufacturer, let alone a different chassis. It's a lot of work but it's not illegal.
      07-23-2021, 04:37 PM   #46
IllSic_Design
IllSic_Design's Avatar
Drives: 09 E92 335i
Thank you for further confirming my posts.... Yes, swaps are def a pain in the ass, but you can swap most anything if it follows what I said in my first post
Dankrupt187.00
540iSUP704.00
      07-27-2021, 12:01 PM   #47
Fritzer
No one sleep in Tokyo
Fritzer's Avatar
Drives: 2011 E90 328i//1995 E34 530i
Just when I was feeling nostalgic and missing California. Hahahahahahaha!
2011 E90 328i, 1995 E34 530i, 1992 E32 740i, 1991 E34 525i
      07-30-2021, 11:38 AM   #48
Coi
Found another article with a good explanation of the new testing procedure: https://www.thedrive.com/cars-101/41...tune-flash-faq
Would be interested to hear if someone has failed after flashing back to stock or has passed despite a tune. Or what the process through the referee is like in the case of a fail. Anyone had their car smogged in the last couple weeks?
540iSUP704.00
      07-30-2021, 06:36 PM   #49
IllSic_Design
Drives: 09 E92 335i
Someone posted in the MHD or one of the other threads that they flashed back to stock and passed.
Coi288.50
540iSUP704.00
      07-31-2021, 11:16 AM   #50
pikkagtr
Go Spurs Go
pikkagtr's Avatar
Drives: 2022 GR Zupra
You can only swap engines that is designed to go into cars into another car
Ie no truck engines into cars and vice versa
Now it is even harder as you can't even unlock Ecu for immobilizer bypass since it may create a different check sum and cause it to fail smog
It's a lot of backwards laws happen, and it got worse
It's not about emissions since a newer engine will ALWAYS run cleaner than one that is 20 yrs older
If it was about cleaner air , they should ONLY care about what comes out the tail pipe
540iSUP704.00
      07-31-2021, 10:40 PM   #51
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
It is about emissions. Always has been.
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line
      09-08-2021, 12:25 AM   #52
Unspec
Unspec's Avatar
1300
Drives: 2015 BMW 535xi
Originally Posted by ried View Post
Virtue signaling nonsense. Just pissing in the wind while China pollutes more than all other industrialized nations combined.
Yeah, those damned bootmod3 tunes are really making life miserable for us locals, arent' they?
Talk about a straw man argument.
I'm not pro-smog. I don't remove or disable emissions-related equipment. But people should be able to apply a simple tune to their ECU if they want to.
Those who live in glass houses should not throw stones.
2015 BMW 535xi
Bootmod3 Stage 2 | ER charge pipe | ER Catted DP | Remus Exhaust | Gplus FMIC | KW V3 | Turner Monoball thrust arm bushings | Wallet regrets
ISTA VM Setup/Tutorial
________4158.50
      10-28-2021, 07:28 PM   #53
jv004
Drives: X3M Comp
Any recent Smog check experiences people has had with pure turbo and tune installed since this dumb unnecessary thing was enacted?
I've been planning to get PS2 and I'm now ready to upgrade but now I'm not too sure....
540iSUP704.00
      10-29-2021, 10:42 AM   #54
McGyv3r
Drives: 1989 325i & 2014 335i
2014 BMW 335i  [0.00]
1989 BMW 325i  [0.00]
The point of the OBDII system is that the car monitors how the car runs. You fail smog if the car can't/hasn't monitored. You also fail smog if your emissions are outside of the factory specs.
It's so much easier, faster, and safer to check the computer versus putting the car on a dyno with a tailpipe sniffer.
The checksum just adds up all the 1's and 0's in the tune on your ECU. After years of recording the checksum on different cars, CARB has a database of valid checksums for each car.
Changing the tune changes the 1's and 0's, so you'll get a different checksum. Forcing a known-good value is a felony. You cannot pass the checksum using an aftermarket tune. Stock, MPE, Dinan, etc are all certified, so they will have a valid checksum.
They also check to see if your ECU is locked (supposedly preventing tunes). Even on a stock tune, you will fail with an unlocked ECU.
Hardware mods that can be controlled by a stock tune won't cause a checksum failure. But you'll fail the visual if it looks aftermarket without an EO number.
      10-29-2021, 11:38 AM   #55
Enabled
Drives: 328xd Wagon, M2 Competition
Dinan does not have a matching CVN, so you can't say it's certified. Dinan still requires OBD unlocks and all, because it's 'tampered' data afterall. If they have a CARB number, this may not matter, but in the end, the ecu will fail the CVN checksum.
Also, the ecus can be unlocked and tuned without any traces to CAL ID/ CVN, so it's still not exactly that different. I can unlock these M2C ecus without any trace at all, anywhere.
-2014 328d Wagon, 8HP. Self-tuned, 270hp/430ft-lbs.
-2019 M2 Competition MT, Alpine White. Self-tuned 560hp
-2016 Mini Cooper S, MT. Many plans.
Others:
-E36 328is. 2000 Z3 Roady. 2003 VW Jetta TDI Manual. Estoril Z3M Coupe.
      10-29-2021, 11:41 AM   #56
romero1990
Drives: E92 M3, F25 X3
2017 X3  [0.00]
2009 M3  [0.00]
what does "unlock" exactly mean? as in does it still consider "unlocked" after flashing back to stock?
      10-29-2021, 03:00 PM   #57
jv004
Drives: X3M Comp
So I should be ok if I flash back to stock and lock DME just for the smog? Just want to plan this out before I start smog checks next year and what to prepare for.......
      10-29-2021, 05:05 PM   #58
IllSic_Design
Drives: 09 E92 335i
as has been said many times in here; Flash back to stock and remove any aftermarket parts(charge pipe/bov, DP's) that may have them suspicious of a modded engine.
540iSUP704.00
      10-29-2021, 09:37 PM   #59
TAZ007
TAZ007's Avatar
1847
Drives: 2021 Z4 M40
2021 Z4 M40  [5.00]
It is all about control.
540iSUP704.00
      10-29-2021, 09:39 PM   #60
TAZ007
TAZ007's Avatar
1847
Drives: 2021 Z4 M40
2021 Z4 M40  [5.00]
Wow! This reminds me of the Commiefonia ammunition magazine ban a few years ago. What will they go after next, plastic silverware.
      10-30-2021, 11:32 AM   #61
Enabled
The unlock is a data hack in the dme. It does modify the checksums/CVN, so it will still be considered "tampered".
Others:
      11-01-2021, 04:19 AM   #62
GoneIn4Secs
Drives: BSM F87 LCI (DCT)
Your not making any sense
      11-01-2021, 05:38 AM   #63
________
________
4159
Drives: ________
* you're.
And by pointing out hypocrisy, he made sense.
      11-01-2021, 10:50 AM   #64
GoneIn4Secs
Originally Posted by Onesie View Post
* you're.
I dint see any hypocrisy, did you?
      11-01-2021, 10:53 AM   #65
________
________
4159
Drives: ________
* you're.
Of course. Hence my agreement.
      11-01-2021, 02:14 PM   #66
GoneIn4Secs
Your not saying much of anything, neither is the guy who you are trying to defend
Commieofornia has just had its recall election stolen in front of everyone, whats happening there is a early indicator of what 'they' plan on rolling out to the rest of the country
People need to say No!
Tags
california, ecu, ecu bmw tuning, n54, n55, piggyback, smog, smog check, tune, tuning
