09-03-2018, 01:11 PM | #2 | |
Problem Solver
111
Rep 416
Get a 4D or 5D roof wrap for 150 bucks... boom CF roof
You need people like me so you can point your f*ckin' fingers and say, "That's the bad guy". "Das ist der Bösewicht". |
09-03-2018, 03:20 PM | #3 | |
Rep 43
Seems some on here have spent a lot modifying their cars and I was curious. Im not a fan of carbon wrap. It’s my pet hate. |
09-03-2018, 06:06 PM | #4 |
Rep 998
Swapping a CF roof requires cutting out the stock roof, sourcing an OEM m6 roof/headliner, welding stock m6 support beams, gluing in the OEM roof, then coding out stock moonroof electronics. Total including parts and labor will probably run you around 8-9k. Considering how this will probably hurt your resale value, you would be better off selling your 640/650 and buying an m6.
09-04-2018, 11:44 AM | #6 |
Rep 11,891
yep agreed, it's not an easy job.
The only OEM retrofit BMW has offered (will offer) to date is the F87 M2 carbon roof port/dealer installed retrofit. BMW is charging about $8k to do it. I will also add, because the structure of the car is going to get modified to make this roof fit, you're at the mercy of how well the shop did the install. You can have a lifetime of creaks and leaks if not properly fitted. The good news is, the CF roof doesn't have to be custom made. You can fit the M6 roof onto the unibody. The question is, where are you going to get a roof? You're more likely to be able to get a shop to custom make one like RKP or IND cheaper than BMW, which currently is about $2600: https://f87.bimmerpost.com/forums/sh....php?t=1309018 https://www.m3post.com/forums/showthread.php?t=528825 Also, what do you mean "loads" of people retrofitting the M2 and E46? These are not cheap jobs. I cannot see that many people doing this to a E46 M3, a car worth no more than $13k these days. The M2 retrofit is still a new concept.
08 Speed Yellow 911 GT3 Sharkwerks 12 AW/Cinnamon X5d Sports Pkg (retired) 14 AW/Beige M6GC ZCP, MPE, V2 steering wheel, vorsteiner (retired) 08 SSII/Black E90 M3 (retired) Last edited by Flying Ace; 09-04-2018 at 11:49 AM.. |
09-04-2018, 12:18 PM | #7 | |
Rep 43
It’s common in the uk for people to fit csl style carbon roofs to a e46 m3. They have recently shot up but you could buy a clean one for £10k not so long ago. There are loads of cheap rough ones available that have been badly modified. They weren’t so desirable a few years back as they were common and cheap. Carbon roof retrofit on a e46 is nothing new in the uk or Europe. It’s also a lot cheaper than what bmw are quoting. Last edited by Kev.k; 09-04-2018 at 12:23 PM.. |
09-04-2018, 11:47 PM | #8 | ||
Rep 998
