      07-10-2018, 04:19 PM   #1
MARKPRIOR
156
Drives: 2017 M6 GC
Coding - E-Sys (HUD Blinkers)
so i downloaded the Virtual machine with esys installed earlier, got everything i wanted enabled
M Startup display
Sport to display HP & Ft LBS
mirrors folding at .5 seconds
video in motion
Video codecs from USb
Bright Halos with lights
legal disclaimers all removed
& more
but i just couldnt get the blinkers in HUD, has anyone manged to get this to work through esys or another program ?
Current: 2017 M6 Gran Coupe
Previous:2014 640D GC 383BHP + 733NM, F10 2010 530d 520i (2000), E36 comact 318i, E46 M3, E46 318Ci, X5,
Non BMW: 5x Skyline / GTRs, 5x Supras, 2x Nissan 200sx s14a, lots of other stuff
      07-10-2018, 07:25 PM   #2
jamodeo
Drives: 2020 M8 Comp Coupe
Did you code the KOMBI or just the NBT? You need to have all three of these set and coded:
KOMBI => 3008 => HUD_PIA_BLINKER => aktiv
KOMBI => 3000 => BLINKER_HUD_ENABLE => aktiv
HU_NBT => 3001 => HUD_TURNSIGNAL => aktiv
-Joe
      07-11-2018, 12:15 AM   #3
MARKPRIOR
156
Drives: 2017 M6 GC
Yeah however I did notice my KOMBI appeared as "DKOMBI" within esys, the only effect it had was it reset the idrive & lost the time
      07-11-2018, 04:39 AM   #4
MARKPRIOR
156
Drives: 2017 M6 GC
Seems its to do with the digital cluster
https://f10.5post.com/forums/showthr...ghlight=coding
      07-11-2018, 12:18 PM   #5
elvisisdog
Drives: F06 MSport 2013/09
I was going to ask if you've got the digital cluster. I found a site ages ago that stated if you update to the latest firmware you can get blinkers in HUD. From memory it was the firmware of the HUD.
      07-12-2018, 12:33 AM   #6
MARKPRIOR
156
Drives: 2017 M6 GC
Hmmm need to look into that
      07-31-2018, 04:34 AM   #7
DE4NO
24
Drives: 2011 640d f13 alpine white
Got mine working in the hud along with phone and radio info too, coded using Carly.
Never used esys but sounds like ncs expert I used to use for my e46 M3 a few years back.
      07-31-2018, 02:35 PM   #8
jamodeo
Do you have the digital screen for your speedometer/tachometer though? I thought I remember reading that you can't do HUD turn signals with the 6WB digital cluster but it looks like there might be a solution in another thread through a post above.
2020 M8 Comp Coupe
      07-31-2018, 03:16 PM   #9
DerBosewicht
Problem Solver
DerBosewicht's Avatar
Drives: 640i Gran Coupe
So Mark.. and definitely not to thread jack is it possible to upgrade 13’s to the digital cluster...? I have non digital and got it coded for blinkers to work in HUD..cool feature to enable
      07-31-2018, 04:25 PM   #10
MARKPRIOR
156
Drives: 2017 M6 GC
do you mean retro fitting a 6wb in a f13?
if yes ive not seen much for the 6's but the below was done on a 3 series
https://f30.bimmerpost.com/forums/sh....php?t=1413357
imagine its not to different for a 6, dam expensive though £1300.00
i also didnt find anything regards the fimrware update vs HUD blinker
      07-31-2018, 04:48 PM   #11
DE4NO
24
Ah, that'll be a no, I haven't.
      07-31-2018, 05:10 PM   #12
jamodeo
That makes more sense, I also have the mostly analog cluster (6WA) and have activated HUD signals successfully. After further reading, it does not look like you can enable HUD turn signals in DKOMBI with the digital 6WB cluster sorry OP.
-Joe
2020 M8 Comp Coupe
      07-31-2018, 05:13 PM   #13
TT BT
The cars we drive say a lot about us.
TT BT's Avatar
49
Drives: 2020 BMW M850i
i had my 2014 650i coded yesterday and the guy that was doing it told me that the blinkers cant be done if you have the digital screen. on my 2013 m6 it worked with no problem....of course no digital screen there
A bad day at the Racetrack beats a good day at the office
