08-05-2020, 04:21 AM | #1 |
Rep 113
BMW F12/F13/F06 DIY LCI Adaptive LED Headlights Retrofit
I have retrofitted for a total of $900.
It was completed by changing the PIN of the FRM and headlight connector respectively and changing the power supply of 15A and added CAN3 from ZGW Last edited by maron; 08-05-2020 at 04:39 AM.. |
08-05-2020, 12:19 PM | #2 |
Scott
36
Rep 97
Drives: BMW 640i
How did you do this?
Scott
08-05-2020, 04:35 PM | #5 |
Rep 1,276
Good info.
*** TAX SALE *** Get Cashback When You Order This Month! ** Check Out Our Sale Section!
Phone 725-221-5267 || website www.x-ph.com |
08-05-2020, 08:08 PM | #8 | |
Rep 113
If you are planning an LCI headlight I recommend that you use esys to perform program operations. Change the LCI year of manufacture and type code. If the HWEL of the FRM is not black, the FRM needs to be replaced. Last edited by maron; 08-05-2020 at 08:16 PM.. |
08-06-2020, 07:50 AM | #11 |
Rep 125
08-06-2020, 09:04 AM | #12 |
Rep 113
10-31-2020, 11:50 AM | #17 |
Rep 14
Hi,
my 640d is flooded, I would like to repair it and change also healights. Can you explain me better how to install the new led into my car (2013 led). Thank you very much |
11-01-2020, 06:00 AM | #18 |
Rep 113
11-01-2020, 07:35 PM | #19 |
Rep 113
Before and after
11-06-2020, 03:17 AM | #20 |
Rep 1
Hello,
I am doing the same retrofit from PRE LCI LED -> LCI LED Few questions: 1.When you change from old to new FRM, do you need only to change few pins for headlight function? All other pins remain the same? 2. Could you give more details on how to code new FRM and headlights? I have esys, however my experience is limited I need to change Vehicle FA? If yes, then which FA function i need to change? As i understand, i will need to inject new CAFD into new FRM? What else I need to do beside this and in the last stage "teaching" new headlights with ISTA+ ? |
11-06-2020, 02:40 PM | #21 | |
Rep 1
I'm currently working to retrofit LED headlights on my 2016 F55 and it seems there is no CAN3 on my FEM or BDC module. if you can help me on this topic, please ? Thanks. RAdj' |
11-07-2020, 02:52 AM | #22 | |
Rep 113
① Replacing the old FRM with the new FRM (106D CAFD) is plug and play * VO code only ②The year of manufacture was changed from (ex 0315 or 0717) and the type key (ex 6D02) was changed. I did not need ISTA (+). Last edited by maron; 11-07-2020 at 03:32 AM.. |
